4r44e problem
Old Sep 18, 2003 | 11:58 AM
part time farmer's Avatar
part time farmer
Question 4r44e problem
My 98 Ranger 4x4 3L has 56,000 miles. Going down mild slope in low gear the trany does not brake the truck at all. In 2nd gear I get some braking but loose even that when I shift to low. Same thing happens in 4WD. Any idea what has gone wrong? I just got this truck so I don't know if has always been this way. Help is apprciated.
ptf
Old Sep 18, 2003 | 03:05 PM
mrshorty's Avatar
mrshorty
4r44e problem
I don't really know for sure. If it were an A4LD (Precursor to the 4R44E. In fact the 4R44E is sometimes called the A4LDE), I would have you check the low/reverse servo seals, but I don't know if things have changed in the valve body between the A4LD and the 4R44E.
Good luck.
Old Sep 19, 2003 | 07:07 AM
part time farmer
4r44e problem
mrshorty,
Thanks for the lead. I am pretty much clueless when it comes to transmissions. I guess the 4r44e is not very popular since I also posted this question on the Ranger Station and you are the only one to respond. Safe to say that something is not right with this unit?
PTF
