AC cool off
Old Apr 16, 2018 | 09:15 AM
PagosaFord's Avatar
PagosaFord
AC cool off
Need replacement for r12 refrigerant. I have a 92 Ford f150 the ac is cool needs recharge . I know R12 can be found, at a high cost. Is there a cheaper alternative. My system is in good shape no leaks. What has others used? Any suggestions would be greatly appreciated.
Old Apr 16, 2018 | 09:19 AM
'89F2urd's Avatar
'89F2urd
There are still r12 sources at a reasonable price, but if you need some then that means you have other issues that need to be fixed first. Ac doesn't need to be "recharged" as normal maintenance.
Old Apr 16, 2018 | 09:44 AM
rla2005's Avatar
rla2005
X2...R12 can be sourced at a reasonable price. I snag the small cans on E-Bay when I have a R12 project.
Old Apr 16, 2018 | 05:15 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
There are dozens of 'alternative' refrigerants used in different industries, however they are not intended for automotive use. If you can't find any R12 I would wait, save some money and do a solid R-134a conversion. I did mine years ago, a hiccup here and there but otherwise very consistent performance.
Old Apr 28, 2018 | 09:41 PM
n3kcb's Avatar
n3kcb
It may seem extreme, but it really would not be that expensive to just rebuild the system with all of the correct r134a parts. You just need to order the parts for a 1994 or later. They should all bolt in just like factory and then no more r12.
I did this on my 1991 F-250. I had to do a little modification to the evaporator box and the condenser brackets because of the year difference. Your 92 should work without any modification.
joe f350
Nov 1, 2013 09:30 PM
pop's 4X4
Aug 26, 2011 06:24 PM
bronzeback
Sep 9, 2005 10:01 AM
Chris_ce
1983 - 2012 Ranger & B-Series
Jul 6, 2003 08:44 AM
