2007 Explorer Running Board issues
Old Apr 15, 2018 | 09:02 PM
rowekmr's Avatar
rowekmr
I just got a 07 Explorer Ltd with the power running boards. The passenger side works as it should but the drivers side did not move. I looked underneath and the electrical harness for the running board motor was disconnected and taped up. I took the tape off and cleaned out both ends and reconnected it. Now it just makes the beep noise but does not move. I am hoping it just is jammed up but can not figure how to release the assembly to lower it. I looked online and the electric motor is a discontinued part and hope I don't need one.
Old Apr 16, 2018 | 07:02 AM
shorod's Avatar
shorod
The typical issue with the power running boards is that the limit switches fail so the system no longer knows either when it is fully retracted or fully extended. New switches can be procured from a parts place such as Digi-Key, Mouser, or Newark. You'll likely need to remove the assembly and disassemble to test the switches. If you find a bad switch you may as well plan to replace them all and order extras for the passenger side as well.
-Rod
Old Apr 16, 2018 | 11:33 AM
rowekmr's Avatar
rowekmr
Thanks
Any directions on how to extend them manually? Would that be the first step to check for switches or removing them?
-Rod
Old Apr 16, 2018 | 01:11 PM
shorod's Avatar
shorod
It appears several others have had issues with the pivot points binding as well. That might be an easier starting point. I'm not sure you need to extend them manually to get them where you can work on them, and if that is necessary, I'm not sure what you'll need to do to extend them. Sorry.
-Rod
chackett
May 11, 2016 12:55 AM
nagetech
WTB - Parts & other
Aug 28, 2015 11:06 AM
daveatsunrise
General Automotive Discussion
Dec 7, 2013 11:36 AM
daveatsunrise
Dec 7, 2013 11:00 AM
rivers
1997 - 2003 F150
Sep 21, 2000 09:38 PM
