Electric fan conversation questions
I know it's been discussed a lot about the pros and cons . I was pro mechanical fan before but I'd like to try and electric one for a bit. And if it continuously lets me down I'll just put the mechanicl one back on.
I've got the fan ,all the wiring,and a fan shroud made up. But it don't know what I'm going to do with the thermostat switch. I'm looking for ideas of good spots to put it. I really don't like the idea of putting it in line on the upper rad hose or splicing it in the a heater hose. All the spots on the intake manifold look pretty tight. The only spot I really like is the thermostat housing but there's no holes in there.
Soo.....your thoughts?
I put my switch in a T-fitting in the heater core line. It works, but I think I need a different, higher temperature switch. The one I'm using now closes the circuit perhaps a bit too soon and then never reaches the shut-off temp to open the circuit and shut the fan off.
No performance/efficiency changes noted, not that I expected any. I mostly did it just to make the front-end of the engine easier to work on.
This is my E-Fan conversion done with just about 90% Ford Junk yard parts for under $150 or so (Fan motor new OEM from NAPA)
I used a Hayden adjustable thermostatic switch that used a surface probe which I inserted at the very top of my radiator. It is secured with a small blob of tar next to where the hose meets the tank & fins. I bought it at Advance Auto (their brand, same part #) for about half of what it was priced at Summit. This is it "mocked up" on kitchen table:
This is the enclosure (Radio Shack) That houses all the above :
Taurus 2-speed fan & shroud mounted inside stock F fan shroud:
By removing air pump & doing a mech to elec fan conversion, my 5.8 was MUCH more rev happy & had a much greater throttle response. Better mileage? I can only surmise since I still have tank cross-flow and no accurate way to check. I firmly believe I have greater horsepower availability since there was much less rotational mass spinning although there are plenty here who argue that the alternator makes up for that even though I don't RUN the fan most of the time.
One of the greatest benefits to me besides the above is that with proper soldered push connectors is that I can pull the whole thing in about 5 minuets to do any sort of engine/front dress service, including NOT having to drain the radiator or disconnect hoses.
None of this is 100% permanent & could be changed back easily with the exception of how I suspended the Taurus shroud:
Interior switch control:
Scndsin, your first pic, that's all a foreign language to me. I would like to do this myself though. I'm actually not a complete fool with electronics but all that seems like a bird's nest. Is there a version of that, that just comes ready to plug in? Haha
Also, is the dial in the engine bay to set the temp for "auto on/off"?
I build electrical stuff from scratch mostly. There is a term called "bread-boarding" & I have no idea why...
What you're looking at is 2 bulbs on the left standing for a separate speed of the two speed fan. The other bulb on upper right stands for the AC clutch. When it comes on, the fan goes automatically to "Hi" & back to low when it disengages. All done though the diode that came in that 3 relay box as was done from the factory.
Yeah, the **** on the box adjusts the temp that the fan "auto" runs. I dropped the probe in the oven with the whole shootin'-match sitting on top & with a quality oven gauge scribed temp numbers on the "dial" to ball-park initial adjustment & fine tune with the mechanical gauge.
Whole thing is protected by a 40 amp fuse. The rotary switch had a smaller 20 amp that protects the relay power.
Been working fine for years.
Follow the below link for thermostat housings.
It would make things a lot easier if you would tell us what you are working on, so that I don't have to go searching through your posts.
https://www.summitracing.com/search/...rder=Ascending
