Transmission fluid question?
Old Apr 11, 2018 | 07:15 AM
F100-1969's Avatar
F100-1969
Should I be concerned? I change the transmission pan gasket and filter yesterday. When I unbolted the pan I saw this.
Old Apr 11, 2018 | 04:59 PM
resonateur's Avatar
resonateur
Tranny clutch stuff. Shouldn't be a problem if you change the fluid, unless the transmission is slipping.
Old Apr 12, 2018 | 04:51 PM
JEFFFAFA's Avatar
JEFFFAFA
It is friction material off the band and/or clutch discs. And a bunch of it. I am assuming you are changing the fluid because you are having tranny problems of some sort. And judging by how clean the orange RTV is outside of the gasket I am also assuming someone else has had that pan off recently. Did you buy the truck recently? And are you having tranny issues?
Old Apr 14, 2018 | 03:15 AM
GaryKip's Avatar
GaryKip
Like Jefffafa said, have you changed the fluid before? Or someone else did? That sure looks like a lot of friction material. If you aren't having any slippage issues, just change the fluid. If you start to have problems, it's time to rebuild.
gvrangr98
1983 - 2012 Ranger & B-Series
Mar 9, 2008 08:56 AM
Theoneandonly
1997 - 2003 F150
Jan 27, 2008 08:33 AM
goodwrench
Sep 11, 2007 09:50 AM
GT350Mike
May 9, 2005 12:37 PM
JoseyWales
Jun 4, 2004 04:08 PM
