Sponsored by: Real Truck
Braking problem
Old Apr 10, 2018 | 07:21 PM
JethroW8's Avatar
JethroW8
Braking problem
My 2000 F250 really bucks and shakes when I brake particularly at higher speed. I though I might have a warped rotor so I replaced those and it is still bad if not worse. Any Ideas? As I slow down almost a stop the truck surges as well.
Old Apr 10, 2018 | 09:30 PM
99f350sd's Avatar
99f350sd
Welcome to the site!
Did you replace all 4? And it did it stop better right after you changed them? Check that one wheel isn't heating up more than the others indicating stuck caliper..
Rear emergency brakes ok?
FYI usually when you change the front rotors the pedal shake will disappear completely. Rears not so much but will do it.
​​​​​​​Could have bad bearings in front possibly!
handye9
Jul 14, 2017 02:24 PM
stevef.
May 27, 2015 05:15 PM
wegotjs
Dec 31, 2009 04:02 PM
vdaily89
General Automotive Discussion
18
Jun 24, 2005 12:03 AM
BSWIFT
Aug 3, 2002 06:54 PM
