shock question
Old Apr 8, 2018 | 01:41 PM
X1Lightning's Avatar
X1Lightning
shock question
My 2005 Excursion had a lift on it when i bought it, and its time to replace the shocks.
The front of the truck has a dual shock setup.
How do i determine the right shocks to buy ?
below is a pic of the existing setup
Old Apr 8, 2018 | 02:43 PM
agsmv1's Avatar
agsmv1
I would start with calling BDS and see what they can offer...assuming it is a BDS lift kit.
Old Apr 9, 2018 | 02:18 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Call the guys at shock wharehouse and they should be able to help you.
Bilstein Truck Shocks - Shockwarehouse.com
Bilstein makes the 5150 monotube valved for a dual setup.
If those are to spendy they just replace them with what you have or a rough country. ( both are inexpensive twin tube shocks)
Old Apr 9, 2018 | 08:13 AM
wpnaes's Avatar
wpnaes
Maybe add some split loom around your brake and vacuume line in case that rubbing is degrading the rubber.
Old Apr 9, 2018 | 09:45 AM
X1Lightning
yeah i was thinking i need to do something about that before it causes a problem
X1Lightning
i'll give them a call, thank you
StrokinIT2001
Dec 17, 2017 07:11 PM
inspector747
Feb 11, 2015 02:08 PM
Ford4x4CountryBoy
Feb 14, 2005 10:03 PM
tonkone
Mar 31, 2004 09:47 AM
