Rear Clunking noise
Old Apr 6, 2018 | 01:17 PM
awojtowicz's Avatar
awojtowicz
Question Rear Clunking noise
so it just started the other day. i have a rear clunking noise when i first startup and get on road. it only seems to happen going into turns as i hit brakes. never does it on straight aways. also, only seems to happen after startup. once going it doesnt do it. if it sits for a long while like while im at work it will do it as i pull away from work and then doesnt do it anymore. googled the hell out of it. seen slip yoke videos, maybe broken leaf spring, rear differential bushing, rear caliper? it drives fine no problems but the initial clunk usually going into first turn and then it stops. i drive over an hour to work and its usually fine. it didnt do it at all today so far. seems like rear passenger side. no clue what it is.
Old Apr 7, 2018 | 01:17 PM
alloro's Avatar
alloro
Could be the exhaust hitting. Then as it heat up and expands it might move just enough to stop banging.
Old Apr 7, 2018 | 01:22 PM
Robert Long's Avatar
Robert Long
LSD maybe ?
PagosaFord
Jan 22, 2018 06:00 PM
Benztechnc
2015 - 2020 F150
Mar 20, 2017 08:04 PM
iszatso
Aerostar
Jun 10, 2016 03:06 PM
Johnnyboy1979
1997 - 2003 F150
Dec 21, 2007 06:32 PM
