Sponsored by: Real Truck
5.4 vs 6.2 reliability
Old Apr 4, 2018 | 12:40 PM
kurthb's Avatar
kurthb
From what I can tell there are similarities between the two. Setting aside the plug issue, can it be said that the 5.4L is more problematic? If you search 5.4L issues you have lots of youtube videos...(timing chain/tensioners, oil pump,VCT but nothing for the 6.2L
Could it be that there are just allot more 5.4's with allot more miles and they learned a bit from the 5.4 and made the 6.2 better?
Old Apr 4, 2018 | 03:00 PM
Chuck's First Ford's Avatar
Chuck's First Ford
years and miles.... the 6.2 had to be better....
Learn from history.. or repeat it.
the 6.2 does have a good history. all be it a shorter one. 2011-----------
Old Apr 4, 2018 | 03:44 PM
Louisville Joe's Avatar
Louisville Joe
Not even close. The 6.2L is far more reliable than the 3 valve 5.4L. The 2 valve 5.4L wasn't bad though.
Old Apr 4, 2018 | 03:59 PM
SuperDutyScaler's Avatar
SuperDutyScaler
My 04 5.4 has 168k on it at the moment, all original except oil changes, air filters, spark plugs and cop boots ONLY. Never once has left me stranded, do I wish it was more powerful YES but has it hauled and towed whatever i threw at her YES SHE HAS
Old Apr 4, 2018 | 10:13 PM
Mr. Mcbeevee's Avatar
Mr. Mcbeevee
I would have to say that the 2 valve 5.4 with the PI heads was the best 5.4 engines from a purely reliability standpoint. I have 230k on my 2001 5.4.
Old Apr 5, 2018 | 01:02 PM
Mike1's Avatar
Mike1
What year did the 5.4L go to 3 valve?
Old Apr 5, 2018 | 01:04 PM
Skip1970's Avatar
Skip1970
dos a 99 f250 with a 5.4 have pi heads?
Old Apr 5, 2018 | 04:38 PM
don123's Avatar
don123
More power and reliability with the 6.2 imho.
Old Apr 5, 2018 | 08:22 PM
landscapeguy's Avatar
landscapeguy
The 5.4 2v is actually a really good engine minus one issue that not everyone has, which is spark plugs blowing out. I have an 02 5.4 with over 220k with nothing done to the engine except a knock sensor, intake and exhaust manifolds. It has been an awesome truck, albeit underpowered.
I had an 06 3v and had the phasers take out the engine. It did have more power and i loved the way i6 drove, but I won't have another 3v.
now the 6.2 literally does not have a single common failure point like both versions of the 5.4 have. I absolutely love my 6.2. It seems to have twice the amount of power that the other two have. Tows better, daily driving is better, its way faster, and doesn't have any common problems
Old Apr 5, 2018 | 08:25 PM
landscapeguy
in an f150 it was 04, superduty was 05
Old Apr 5, 2018 | 10:22 PM
SuperDutyScaler
2002 up 5.4 ford fixed the spark plug problem
Old Apr 5, 2018 | 11:23 PM
landscapeguy
they added more threads in the heads to stop them from shooting out, but the 05 and up had a problem where they would break off inside the head when changing them. Not a huge deal if you got the special tool to remove them
Old Apr 6, 2018 | 10:12 AM
Rob89's Avatar
Rob89
The 5.4 is underpowered in the super duty however a properly maintained 2 valve will go 300k+ fairly easily. The 6.2 has more power and the reliability is just as good if not better. I have owned both and 6.2 wins.
Old Apr 6, 2018 | 10:30 AM
hermancm's Avatar
hermancm
if I recall correctly 2004 was when the 3v 5.4 came out.
Edit....Doh! I didn’t see this was already answered...
Old Apr 6, 2018 | 10:39 AM
hermancm's Avatar
hermancm
did they really fix the issue in ‘02? This would be the first I’ve heard of it. I bought a low miles ‘03 SD last year with a 5.4 in it.
