VIN and Engine ?
Old Sep 30, 2001 | 10:46 PM
xaviervp's Avatar
xaviervp
VIN and Engine ?
Does anyone know how I can decode this
VIN number for a 1987 F150 I accuired
with a blown engine to restore it I need
to know what engine it has if it is a
351C,M,or W so I can locate a correct
replacement. 1FTEX15HXHKA25624
Can I replace the engine with a newer model
that has fuel injection but put keep the
carb manifold with the holley from the current
engine, what else would I have to change on the
engine so it runs right.
Thank you
Xavier
Old Oct 1, 2001 | 12:09 AM
Pastmaster's Avatar
Pastmaster
VIN and Engine ?
It came factory with a 351 Windsor. In fact that was the last year of the 5.8L HO. The Modified's last year was 1982, and the cleveland was never in a truck. It's last year was 1974,
1993 F-150
1989 F-150 4x4
http://briefcase.yahoo.com/toydestroyer1
Old Oct 1, 2001 | 11:09 AM
loudfords's Avatar
loudfords
VIN and Engine ?
As far as swapping in an EFI motor & converting to carb goes, you need to swap the timing cover, water pump & accessory drive to use a mechanical fuel pump. You need to swap the distributor too, and changing cams would be a good idea too. You could probably re-use all the external parts off of the carbed 351 that is in the truck to build a new motor.
1979 F150 Custom: 84 351W: 91 heads, Crane PowerMax cam, double roller timing chain, Edelbrock Performer intake & Edelbrock carb
1987 F150 XLT Lariat: 88 351W EFI
86 & 87 Bronco II: next winter's beater
Old Oct 1, 2001 | 01:23 PM
cyclops's Avatar
cyclops
VIN and Engine ?
