Brake lights not working
Old Apr 1, 2018 | 08:30 AM
Patriotic Rottweiler's Avatar
A few days ago I was driving when another driver flagged me down and informed me that none of my brake lights were working. I got to a place where I could pull over and try to determine the problem. I turned on the headlights and emergency flashers and they both worked. Since I was by myself at the time, I was unable to check the brake lights on the side of the road.
I went to another location where I had help and in fact the brake lights were not working. This didn’t make any sense to me as the parking lights, turn signals and emergency flashers were working. I checked all of the fuses associated with the brake lights and they were all good.
So being away from home and needing these fixed quickly, I bit the bullet and went to Ford. As it turned out the part that was broken is the Stop Light Switch (near brake pedal) F87Z-13480-AA. It is a $20 part on Amazon and $30 at Ford (plus install).
Hopefully this info helps another FTE member in the future.
Old Apr 1, 2018 | 10:01 AM
brannman's Avatar
brannman
Glad it was a quick easy fix. I had a similar issue a few years ago and the problem ended up being a short inside the multi-function stalk (turn signal, wipers, etc). There is a wiring path for the brake lights that routes through there...
Old Jun 29, 2018 | 05:56 PM
Codelizard's Avatar
Codelizard
Same issue here, but if i push the brakes hard enough, it comes on. So I believe its the switch. Going to oreilly to buy one for $20.
Old Jul 2, 2018 | 10:21 AM
96firephoenix's Avatar
96firephoenix
Based on my experience with replacing the brake lamp switch on my brother's expedition, spend the extra on the motorcraft part.
Old Jul 2, 2018 | 11:39 PM
Codelizard's Avatar
Codelizard
It was definitely the switch. And I couldnt get a motorcraft until monday, so I went for what i could get, since i needed to drive that night.
Appreciate the input tho. im gonna go ahead and get the motorcraft anyways.
mixerdrvr
May 26, 2013 09:04 PM
Wkbrdr1
Mar 31, 2011 02:54 PM
Lukes66
Feb 9, 2011 05:38 AM
confederate_mudder
Electrical Systems/Wiring
Apr 9, 2007 01:29 PM
