F 250 SUPER DURY
F 250 SUPER DURY
Dear friends, i greet you all. I'm currently fixing ford F 250 series, super duty, 2006 model. Crank no start issues, NO-SYNC / FICM SYNC READING NO when engine is cranking, fault code is(P2614-CAMSHAFT POSITION OUTPUT CIRCUIT/OPEN), being on the truck for a week now and yet truck refuse to start, what is solution to this problem of NO-FICM SYNC when engine is cranking, have change the camshaft and crankshaft sensor and could not resolve the problem,i need wiring diagran for this truck and i could not locate the pcn, anybody know the pcm location arround the vehicle? pls, i need everybody support.
...to add a tad bit more to the location description...behind a heavy metal bracket with a couple of very large electrical connector going to it.
