1963 Lincoln Y Block. Looking for a transmission.
Hey there,
I have a 1963 Lincoln Y block. I know these engines are a bit rare. Best I can tell, for the research I've done, its a 302 or a 332. Mine is an industrial model (it was used as an auxiliary drive in a chair lift), I believe these engines came in F-series 700 ,800, 900, and C-series as well. I'd like to know if anyone knows what sort of transmission(s) will bolt up to this engine.
I have a Clark 5 speed that was on the back of a 332 in an F700 truck tractor. I still have the bellhousing too, but not the flywheel. The engine went away with a Lincoln 368 that a guy was going to stroke. The 332 uses a drop forged crank, so he wanted it to have it offset ground to put in the 368 block. I still have the rams horn exhausts for it too.
Redneckfordf2502002
02-08-2015 10:23 AM
68cabby
03-27-2012 10:21 PM
