6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Cold howl on accel
Old Mar 28, 2018 | 10:27 AM
turbohunter's Avatar
turbohunter
Cold howl on accel
Hi guys
I could use a little diagnostic help. Have recently started hearing what sounds to me like turbo howl during cold accel.
At first I thought it may be belt squeal. Checked the belts and tensioners and indeed had a bad accessory tensioner. Replaced that and hoped for the best. Still have the cold howl. It only happens when dead cold and only on initial accel. Sounds to me like I'm starting to lose the turbo but I'll defer to you guys that are more familiar.
Included a vid link, sorry it's upside down but you only need to listen.
Old Apr 1, 2018 | 03:31 PM
turbohunter
Ok have crawled all over the truck from engine compartment top to underneath while wifey hit the accelerator.
First I’ve ruled out turbo whine. I couldn’t hear the noise from the top of the engine but could hear it underneath. I think not only did I have a bad tensioner but I think it’s the routing/idler pulley that’s bad on the main belt. Also as I watch the tensioner while running it’s kinda dancing a bit.
Old Apr 15, 2018 | 04:48 PM
turbohunter
Wrong cemosabie.
Replaced idler pulleys. Still there.
Well at 200k it’s time to replace ‘em anyway. That’s the way I’m spinning it.
Guess I’ll be crawling all over it some more while wifey guns it.
Old Apr 15, 2018 | 05:46 PM
DieselDenny's Avatar
DieselDenny
It's very tough to find these things. Your approach is exactly what I would do. Take out the known wear items. (not throwing money away as they need it anyway)
I study my *** off and from what your description is, I'm leaning into power steering pump.
Your mileage and my research point right at it. They start failing at your mileage. How is your steering and do you have a note when cold when it's acting up with steering input??
Denny (big shot in the dark)
Old Apr 15, 2018 | 07:01 PM
turbohunter
You may have it right. I don’t drive it everyday but last time I got in it I thought the steering was a bit, uh, how do I describe it, tougher to turn but that may be overstating it.
Anyway thank you for your thoughts. As I think about it I couldn’t hear the noise up top much and it might be more driver side oriented and down. I’ll look at the pump next.
Thanks again.
Old Jun 3, 2018 | 01:25 PM
turbohunter
FOUND IT
I can’t tell you guys how much I’ve been crawling all over this truck. It wasn’t the front of the engine at all. Was checking all the down pipes and up pipes for cracks because it was very boost related. You could play with the pedal and tell it wasn’t a pulley. No cracks in any pipes but in following the boost and exhaust patterns, boom, there it was. One of the passenger side bolt holes was empty and there was soot around it where the rest of the engine was spic and span. The rear exhaust manifold bolt broke and because there are two steel gaskets it is making a whistling sound when it gets boost.
So now my only problem is getting some time to make the repair. In saying what the dealer would charge and taking a couple days off against it, I think I’ll be taking a couple days off (though this is going to be an epic pain in my keester).
Old Jun 4, 2018 | 12:44 PM
turbohunter
Hah, just found this thread.
This is exactly the problem I have.
https://www.ford-trucks.com/forums/1...bo-squeal.html
Old Jun 12, 2018 | 05:00 PM
turbohunter
2 days in and it’s out.
Now to drill the bolts out.
This thread has helped a bunch.
https://www.ford-trucks.com/forums/1...old-bolts.html
If you ever have to do this job just know it’s a weeks worth of work (at least for us old guys).
Old Jun 12, 2018 | 10:14 PM
Firefighter 1406's Avatar
Firefighter 1406
Good work. Thanks for the threads. I hope I never have to worry about this.
Old Jun 13, 2018 | 06:44 PM
turbohunter
I did it.
Today was bolt drilling day.
The first one would not take a straight bit into it. Kept shoving it over to the side. It came out in pieces and one side of it was pretty much welded to the threads. It pushed the bit away from the somewhat welded area. But With the help of a dremel and some new cool bits I could chew away at the welded part and finally cleaned it out with a tap and thread chaser. And that was the easy to reach hole, thank goodness. If it were the hard to reach hole it would not be good.
The second hole took a very nice center punch and I could get an almost perfect center on it. Had to go very slowly though. I had ordered some McMaster Carr reverse drill bits which weren’t cheap and had to cut down the length of the two larger sizes in order to fit behind the frame. At 3:05p I finally got the second bolt to break free.
3 days and counting. But it’s all downhill from here. Tomorrow I’ll get the manifold back on then a slow rebuild should be done Friday.
Old Jun 13, 2018 | 06:50 PM
Firefighter 1406
Congrats. Had you got them out. Had to do this on my wife’s 5.4 in her expedition. While not even close to as tight as our 6.4’s it still wasn’t even remotely fun.
Old Jun 13, 2018 | 06:58 PM
turbohunter
Thanks man I’m feeling pretty good right now but it’s a bitch of a job.
Old Jun 13, 2018 | 09:18 PM
Firefighter 1406
I will take your word for it for sure.
Old Jun 14, 2018 | 05:40 PM
turbohunter
Good day on the truck today. As expected the manifold took all morning to get in and torqued down. Got the rest of the bottom end back together in the afternoon (starter reconnect, a/c back tight, alternator back in and belt on).
Just amazes me that there are only a few easy bolts to get in. Gotta get your attitude straight to get ‘er done.
Old Jun 15, 2018 | 01:09 PM
turbohunter
It runs and it’s freaking quite.
Took it out and drove around for a while. All is well.
I guess this is the end of the thread.
