so today I was going on about a 30 minute drive. I always seem to monitor my EOT and ECT, and they usually average about 15 degree difference. Well today other things started happening. After about 25 min of the drive I started noticing both of the temps started stretching and soon to be about a 23 degree difference and my wrench light came on which is the electronic throttle control. I monitor the temps with my SCT livewire monitor so of course went to go check the dtc codes. Turns out it threw a P012f code saying “Engine Coolant Temperature / Engine Oil Temperature Correlation”. I eventually got to the place I was going to and turned off the truck and cleared the codes and turned the truck back on and it never came back on again. So I then leave after the truck was sitting for about 2 hours and go back home my trucks EOT was reading 193 and my ECT was 174 being a 19 degree difference. I need help on where to start.
Update: I got home and let my truck sit for about an hour until I went to go get diesel. I checked coolant level before I left and it stood at the minimum level of the bottle which I hear is the new maximum level, and after I came back home I checked degas bottle again and my degas bottle was nearly full and looked like it was on the verge of puking!
Was it at operating temperature? That's an expansion tank, the volumetric expansion of 8 gallons of ethylene glycol (the only coolant on the list I found) can expand almost half a gallon at operating temperature. Cut that with with water we're still talking an inch of change in the degas bottle can be normal. That's why the level was reduced, and the old full mark normal coolant expansion would cause puking absent any problem other than the expansion tank volume wasn't enough.
Your ECT temp was low when you looked the second time, don't check until ECT is up to at least 186*f (you'll read 190*f, but 186-188* is normal for an OEM t-stat to run and close enough for this). It sounds like you need an oil cooler, nothing more major than that. The wrench light was programmed in on later PCM strategies, it did it's job and told you to check. You'd notice if the oil cooler ruptured because the expansion tank would be fill of chocolate milkshake oil/coolant mix.
so maybe I should let it get up to about 180-190 ECT and do a delta test on the highway and compare ECT and EOT?
