I need more power captian!
Old Sep 17, 2003 | 09:09 AM
P37-007's Avatar
P37-007
Well not actually more power, just more speed. I steped up in the world I go rid of my 96 4cyl and got a brandnew
2002 Ranger XLT
4x4 4.0
4.10 posi
4 door
Stepside
Mach 1 headunit
Skid plates
Everything
Got it al for $17,000
Anyway back to the question this truck is governered my old one wasn't. I can't go past 93 mph how do I fix this?
Any help greatly appreciated Thanks.
Old Sep 17, 2003 | 09:38 AM
PSKSAM2's Avatar
PSKSAM2
Easy, shave some weight off your lead foot. Seriously, it seems more than a little scary to do 93+ in a high roll center vehicle most likely with tires that aren't rated for that speed.
-Jim
Old Sep 17, 2003 | 10:34 AM
Superunknown98's Avatar
Superunknown98
your running 4.10 gears, you must be getting like 10MPG at 93 mph. change the gearing to a 3.73 or 3.55 for more top end, but then your acceleration will drop to. This isn't easy to do though, it would be kind of expensive.
Old Sep 17, 2003 | 12:43 PM
WXboy's Avatar
WXboy
You know, I've always thought this too. But last weekend I was coming back from Cincinatti on I-75, and traffic was running around 90 mph. So my new truck was maxed out (by the computer) just trying to "go with the flow". I was not happy.
These trucks have so much more power to give, yet Ford won't let them give it with that silly computer program. I don't think driving fast on a regular basis is something anyone should do. But occasionally it happens, and it's foolish that my $25K truck cuts me off before I'm done.
So far, the only way I know of around it is with a chip. And if you get a chip burned for your truck, you'll have to use 93 octane all the time, which almost makes it not worth it.
Old Sep 17, 2003 | 01:31 PM
jt-stl's Avatar
jt-stl
Correct me if I'm wrong fellas, but can't you use a programmer, like the ones hypertech make to adjust the rev limiter and tweak the other specs to squeak out more power for the lower octane fuel?
Old Sep 17, 2003 | 02:33 PM
WXboy's Avatar
WXboy
I don't know, but if it can be done let me know and I'll buy one.
Old Sep 17, 2003 | 08:25 PM
rangersvt04's Avatar
rangersvt04
your 02 stops at 93 ?! my 96 3.0L stops around 100-105. try a chip or a programmer.
Old Sep 17, 2003 | 11:10 PM
Rand's Avatar
Rand
The ranger wasnt designed for that speed. You will get harmonic vibrations that will eventually cause your whole driveline to fail.
Also A stock ranger is downright scary at 90+
You might want to look into lowering and putting some performance tires on.
If you want to go 90+ I suggest something made/designed to go that fast.
That being said a chip will eliminate the limiter.
Rand
Old Sep 17, 2003 | 11:35 PM
cow_boy104's Avatar
cow_boy104
My 2000 was the same 3.0 stopped at 104
Old Sep 18, 2003 | 02:37 AM
Hammy211's Avatar
Hammy211
I don't know if this will work with a 4.0, but maybe you can find something like it. If your 4.0 has an auto I would just go for the chip and get some performance gains while you're at it.
Old Sep 18, 2003 | 02:38 AM
Hammy211's Avatar
Hammy211
Opps, forgot to include the link.
www.rogueperformance.com/vss.html
