Shift on the fly question
Old Mar 21, 2018 | 06:44 AM
miranda machining's Avatar
miranda machining
I just bought a new to me '05 F350 Super Duty FX4 with the auto trans. I have seen this term "shift on the fly" and I am assuming it means that you can shift into 4x4 hi while the vehicle is moving. Am I correct in that and if so what is considered to be a safe speed to shift.
I also have a '95 F350 5.8L with manual hubs and I would often leave the hubs locked in for the winter and shift into 4x4 while the vehicle was moving but tried to keep the shifting speed down to no higher than 40mph or so. I really don't have a good reason for that it just seemed like a good idea to me.
Thanks for the help for this 6.0 newbie.
Old Mar 21, 2018 | 07:55 AM
navistarnut's Avatar
navistarnut
Not sure there is a right or wrong answer. I've always made sure I was around 30 mph or less when engaging with no wheel spin, just a habit I guess.
If I was at cruising speed and then no longer needed 4X4 then I don't care what speed I disengage as long as it's not uphill.
Old Mar 21, 2018 | 08:12 AM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
That is correct you want to let off the gas pedal then flip the switch into 4x4. I don't think theres any speed limit for shifting into 4High. Just don't want to be under load climbing a hill etc.. It will shudder hard on you if you do.
Old Mar 21, 2018 | 08:50 AM
jsm180's Avatar
jsm180
My owners manual says up to 55 mph for 2wd to 4wd hi, need to be stopped for switch to 4wd low.
Old Mar 21, 2018 | 09:01 AM
mhatlen's Avatar
mhatlen
There you go, I was up in the mountains a few weeks ago and we were going up a slight grade at night and it was icy and I didn't see it till I went sideways at about 30mph. I had light throttle when I flipped it to 4 High and I got a growl and a shudder when it kicked in. OOOps my son looked at me funny with a that didn't sound good comment.
So I threw him out in 10* weather and kept going. lol
So just remember no throttle when you shift into 4x4 and the truck wont care.
Old Mar 21, 2018 | 09:37 AM
miranda machining
Thanks guys. I figured it was about the same as manually shifting so yeah -let off the throttle. Up to 55 from 2 to 4hi - perfect that's what I was looking for!
ZachinCO
16
Sep 19, 2020 07:12 PM
coffia82
1997 - 2003 F150
Dec 27, 2009 12:32 AM
EFF250
Dec 17, 2007 08:32 AM
RotGrubestier44
24
Nov 30, 2005 03:16 PM
RyanGruhn
1978 - 1996 Big Bronco
Jan 3, 2003 09:52 PM
