Spring 2018 - early 2019 BC Chatter. Lets get at 'er.
#1307
Received 4,234 Likes
on
Finished up my brake lines today and modified one inner fender and have it back on. Will modify the other tomorrow get it on then bleed the brakes and get it sitting back down on rubber. Will likely have to adjust the coil overs for ride height then try and dial in the alignment as close as I can get it and hopefully drive it down for the final alignment before the season ends..
#1308
Sounds like you had a productive day, I puttered on the shed doing a couple of tedious jobs like making shelf bracing and cutting up old fence boards and putting them in as the upper back wall.
#1309
on
#1311
on
#1313
on
#1315
on
I still manage to get the odd stone chip but no road construction this year except going north of me but that's finished too..
#1316
In 2 months all the roadwork on the main drag in my neighborhood is supposed to be done including the topcoat of pavement and finally we'll be able to drive a straight line down 17th instead of from one lane to the other.
#1317
#1320
on
