light miss on acceleration( update)
I apologize if this has been asked and answered before but Ive read thru many of the 6.0 threads and cannot find an answer.
Anyway,,2006 F250 has been deleted but no other mods .it starts good, no smoke of any type and will idle smooth all day.
On acceleration it has a (lite miss) more of a stumble or tremble.At highway speed it runs smooth until you start up a grade or try to speed up
and the stumble will return .once on level ground it will smooth out.
I have no check engine light and have checked for codes and nothing showing up
You won't get any codes for low fuel pressure.
Has this truck had the blue spring kit installed in the upper fuel housing?
Don't get a cheap knock off.
It would be a real good thing to get a thread adapter for the upper fuel bowl so you can put a pressure gauge on the fuel system for testing the fuel pressure. Blue spring is a great idea regardless. May be able to rent a gauge at a parts house or you can buy a hose and gauge long enough to get it to windshield.
Then take truck for a drive while watching fuel pressure.
FYI low fuel pressure is a injector killer.. Happens fast too BTW.
trukn07
11-18-2015 11:30 AM
HardCorps88
09-09-2013 02:15 PM
