Gauge question
Old Sep 16, 2003 | 10:29 PM
lightning99svt's Avatar
lightning99svt
Gauge question
I just bought a '79 F150 with the idiot lights instead of the oil pressure gauge. Can this be swapped with a gauge cluster easily, or is the wiring harness totally different ?
Old Sep 16, 2003 | 10:58 PM
Mil1ion's Avatar
Mil1ion
Gauge question
No.....The idiot light gauges require a 14 pin connector while the gauge clsuter requires an 18 pin connector.
The only way to get it, is swap the whole wiring harness under the dash.
Old Sep 17, 2003 | 06:48 AM
chevdog's Avatar
chevdog
Gauge question
You could also add an oil pressure gauge in the cab and tee off of the oil pressure sender fitting, or even add a triple set of gauges for oil/water/volts.
I just bought a triple set of Sunpro mechanical gauges from the Actron website garage sale for about $20 - that's a pretty good deal.
Old Sep 17, 2003 | 04:21 PM
lightning99svt
Gauge question
Thanks for your help, I see the work I'll need to do.
