WHD or not
Old Mar 23, 2018 | 08:25 PM
pspc271's Avatar
pspc271
Originally Posted by amartz02
I didn't see that anyone else asked, did you readjust the WD hitch for the new truck or did you just pull the hitch out of the old truck and try it on the new? These new trucks are bit taller, the hitch may need to be adjusted. If you did readjust, I'd say go weigh it with and without the bars attached and then the truck by itself to see how much weight is being transferred. If you lifting weight off of the front there could be reduced steering and braking. Otherwise the Fastway could be helpful with sway control.
I did adjust the hitch. Actually I had to buy a completely new drop shank because the one I had with the Ram didnt allow for enough drop from the higher bumper hitch height.
Siriustoo
All Things Towing
Jan 23, 2017 01:27 PM
smcrea
Feb 10, 2015 08:26 PM
BPofMD
All Things Towing
Aug 6, 2013 10:14 AM
Customz
All Things Towing
21
Mar 10, 2005 12:51 PM
BigF350
All Things Towing
May 17, 2004 11:44 PM
