My 1957 F100 build
  #196
Old 10-17-2020, 07:46 PM
spurredon's Avatar
spurredon
spurredon is offline
I don't think my little tired out 223 would even turn those over! Huge rubber!
  #197
Old 10-21-2020, 10:28 PM
HyePo57's Avatar
HyePo57
HyePo57 is offline
G-Force...you gave me a great idea as I too am putting in tilt column... (needed to get tank out of cab first to finish off interior)....
love this... much easier than trying to deal with that mal-fitting two piece rotter and rusted dust blower at the bottom of my column... i can see the road go by as I drive. LOL
thanks
  #198
Old 10-22-2020, 10:55 AM
G-Force junky's Avatar
G-Force junky
G-Force junky is offline
You are very welcome, glad I could help!!
  #199
Old 11-20-2020, 12:33 AM
G-Force junky
So I didn’t like the mounting brackets on my radiator and I wanted to move it forward a bit for more clearance so I cut off the brackets, made some new ones and welded them on.
I recently purchased a tig welder so it’s a good time to brush up on my aluminum welding.
  #200
Old 11-20-2020, 12:36 AM
G-Force junky
Before
  #201
Old 11-20-2020, 12:39 AM
G-Force junky
After
  #202
Old 11-20-2020, 12:43 AM
G-Force junky
Now I just have to drill the the mounting holes and I’m done.
  #203
Old 11-20-2020, 05:35 AM
Walston's Avatar
Walston
Walston is offline
Welds look good, nice job.
  #204
Old 11-20-2020, 11:10 AM
G-Force junky
Thanks Walston! I know they’re not the prettiest but I know they’ll hold.
Tig welding is definitely something that takes time to get good at.
much respect for all the dime stackers!!! Hopefully I get there sooner than later.
  #205
Old 11-20-2020, 04:35 PM
spurredon's Avatar
spurredon
Those welds are not that bad. TIG is much more of an art form than MIG. Looks like they will work just fine!
  #206
Old 11-20-2020, 04:48 PM
G-Force junky
Thanks spurredon!! The pulser setting on the welder helped lol
  #207
Old 11-22-2020, 11:28 PM
G-Force junky
Finally fit the rad today but it was kind of a pain in the buttocks! Realized the rad isn’t square and neither is the rad support so I had to do some trimming to make it all look square. Also had to modify the fan shroud a bit but that wasn’t bad.
the shroud still has the protective wrap. In case you were wondering lol
  #208
Old 11-23-2020, 01:23 AM
oldbleu's Avatar
oldbleu
oldbleu is offline
Did you fabricate the shroud yourself or did you find one already made? It looks good. What is the diameter and make of the fan? I am probably going to have do something like this for the Farm Truck.
  #209
Old 11-23-2020, 11:01 AM
G-Force junky
The fan and shroud are champion. The shroud comes with the hole cut out for a 16” fan. The fan I’m running is a 16” Spal.
  #210
Old 01-19-2021, 11:14 PM
G-Force junky
So I thought I’d sort out my rad hoses out and figured I would cut the thermostat housing hose connection or and weld a new pipe in the direction of the rad so I could use a 45 degree silicone rad hose.
Quick Reply: My 1957 F100 build
