I'm looking at another f-150. the axle code on the door say "18". it's an '85 (made in 06/85), I know it's an 8.8", and I am assuming the gear ratio is 3.08. is that correct??
another thing: I have a powertrax locked 9" with 3.50 gears in my other truck (well, actually a frame now). If the above truck has 3.08s, I would be wondering if a dana 44 3.54:1 would work correctly in the front (I know most 8.8s are 3.55), and what would someone expect to pay for a 3.54 gear dana 44ifs pumpkin? (like $50-100?)
yes door code 18 is a open 3.08 8.8 unless someone swaped it on you already. To be sure u could just check the axle tag. As far as the dana 44 goes im not sure but surely someone else on this exelent site will.
My 1984 spec book says an axel code 18 is a 3:08 Ford. You will have to look at the tag to tell for sure. The ford has the ratio (3.08) on the bottom of the tag. The Dana has the ratio on the top of the tag.
OR....you could do it the old fashioned way......turn the tire one full rotation and count how many times it takes the driveshaft rotates.
The axle tag/codes will not always give you accurate info...If I ever sell my truck no one would ever know by looking at tags or axle codes that I swapped in 4.56's from 3.55's
-Jason-
PS...I would not ever try two different gear sizes regardless of how little difference there is between them....too much to risk!!
Typically to match 4x4 axles you round to the nearest 1/10th. if you have a 3.54 it'd round to a 3.5, a 3.27 would be a 3.3, a 3.73 would be a 3.7, stuff like that. So long as both of your axles round to the same 1/10th you'll be fine (such as 3.54's and a 3.5, it'll work fine).
