ford 300 torque possibilities?
Old Mar 17, 2018 | 01:48 AM
nick83f150's Avatar
nick83f150
hello, i have a 1983 f150 with the 300 i6. was wondering if it could be built to make about 500 ft lbs of torque reliably using a turbo. im not looking to spend a fortune on this was thinking some headers, an offenhouser intake and 4 barrel 600cfm carb, and a turbo from an old powerstroke.
Old Mar 17, 2018 | 05:06 PM
fordman75's Avatar
fordman75
Originally Posted by nick83f150
hell, i have a 1983 f150 with the 300 i6. was wondering if it could be built to make about 500 ft lbs of torque reliably using a turbo. im not looking to spend a fortune on this was thinking some headers, an offenhouser intake and 4 barrel 600cfm carb, and a turbo from an old powerstroke.
What's the deal with the 500 ft/lb #? Is it just to have some bragging rights? Or do you need it to do a specific task. I say don't get so hung up on #'s. Build it to do what you need or want it to do and be happy.
But to answer your question. Yes & No. Yes it could be built to make 500 Ft/lbs. with a turbo. But you are going to have to spend some money or it won't last. You could do a budget build and try to make the #'s. But it will be a ticking time bomb. You won't know when but it will blow. You have to build the engine to handle the boost. If you just throw a turbo on a stock 300 it will eat itself. The ring end gaps will close up and break a piston and most likely destroy the cylinder when it does it. If you are lucky it will blow the head gasket before it breaks the pistons. You'll need either ARP rod bolts or custom rods, stronger pistons, larger ring end gaps, head studs, better head gasket, a fuel system that will support the boost. You will need to modify the carb or buy one set up for a blow thru set up.
Old Mar 17, 2018 | 06:56 PM
nick83f150's Avatar
nick83f150
I was thinking arp hardware all around. Open up the ring gaps. New gaskets high volume oil pump and water pump but stock crank rads and crank. It doesnt need to be 500 exactly it would just be good to have some power in case i need it. Just some more torque than what it has currently. Will i need to hone the cylinders and rods or should they be fine they way they are with arp hardware.
Old Mar 30, 2018 | 05:39 PM
ThiccSix's Avatar
ThiccSix
Here is a video on turbocharging the big six. Intersting build.
https://youtu.be/2l3hL1W3lMs
Old Mar 30, 2018 | 09:13 PM
ThiccSix's Avatar
ThiccSix
Well Lutz you're right. I just did some research and it turns out the 4 barrel holley 390 cfm will be PLENTY for the mild build on a 300 the two webers would combine for like somewhere over 700. 10.5 cr seems really tight for the 300 considering it's stock about 8.1. 9.5 seems a more reasonable goal.
ford300fan
13
May 14, 2017 05:44 AM
Chris Braun
May 6, 2014 12:19 PM
6inarowmakeitgo
83
Nov 11, 2012 07:16 AM
Twilight Child
16
Nov 23, 2004 04:58 PM
warren b
Jan 20, 2003 03:52 AM
