2006 V-10 engine Knock
Hello all,
My 06 F-250 developed a metallic knock this afternoon. Had it towed to a friends shop.
Gauge showed good oil pressure but factory gauge seems a bit sketchy to me.
Truck is on the lift and ready to be diagnosed. A few questions I have.
1) Is it at all possible to drop the pan while engine is in the truck?
2) Should I attempt to install a more accurate gauge and see a true oil pressure.
a. Where can I tap a gauge into the oil system?
3) Should I be looking under the valve covers or timing cover ? Possible cam follower or cam tensioner ?
There is no CEL or engine miss when engine is running. Just a knock that is noticeable at hot idle and increases in volume till about 2,000 RPM
I had a knock above 2000 rpm. 2000 Excursion 4x4.
I jacked up motor and removed oil pan. #1 rod bearing was beat up. All others were in great shape.
took me 1 day to jack up motor and remove oil pan.
1 day to put tri metal bearings in all rods.
1/2 day to put back togather.
I think the cause was a bad injector clip. That cylinder was dead.....intermittently due to the clip on injector being broken.
Not sure when my knock developed. I bought it with 98,000 miles on OD. At 108,000 I put a supercharger on it and noticed a knock above 2000 rpm.
like I mentioned, I only had 1 bad bearing and I kinda think it had to do with a broken injector clip that was present when I purchased the vehicle. I cant figure any other reason for it because #1 sees better oil pressure than most and all others were pristine.
