I had a build date of 3-12-18 and logged onto COTUS today and noticed I had a window sticker and it shows it was built on 3-7-18. Still shows in production, but hoping it makes it to Virginia a week earlier than expected!
Fingers crossed for you. Mine was built almost a month ago and just made it to VA last week. Where it has now sat waiting to be picked up by a truck and taken north to my point of VA at some point.
The window sticker does not have the build date on it. It has 2 dates, one was when the window sticker was created (i.e. unit "sent to plant"). This is the smallest date on it and this date tends to be about a week before the unit is built. The second date is when the .pdf file you were viewing was generated it is the larger one at the bottom. Given the date on your sticker I'd say it's more likely that your unit actually is being built on 3/14. Given that COTUS still says "in production" would seem to back this up.
Mine moved to In Production on 3/7 and as of today, 3/15, it is still in production. The delivery date of 4/7 is still the same, though. Not sure how long it takes to build a truck but surely it isn't 8 days.
Mine moved to production on 3/9 and still there also. Mine has a scheduled delivery date of 3/27. I keep expecting the delivery date to get pushed out. I’m a 3 hour drive from the factory, so who knows....
