diff covers
Old Mar 12, 2018 | 04:11 PM
KAGAN21's Avatar
KAGAN21
diff covers
hey guys i know this has probably been discussed but can't find any info. Im looking for a new diff cover that has a temp sensor port i seen this one from summit looks like it would work but don't know.
https://www.summitracing.com/parts/t...0500/overview/
and another thing when i go to change out the gear oil if i want to use synthetic which one would i use?
Old Mar 12, 2018 | 06:13 PM
rla2005's Avatar
rla2005
If your truck is a F150/Bronco that cover will fit. Personally I think it is overkill. 75w-90 fluid will work fine. If you have a limited slip differential you may need to add some of LS additive. Not all fluid is made the same.
Old Mar 12, 2018 | 08:23 PM
Diesel_Brad's Avatar
Diesel_Brad
That is not a temp sensor port
The two largest holes are fill and drain.
The other two smaller holes are for studs to push on the bearing caps
Old Mar 12, 2018 | 09:55 PM
KAGAN21's Avatar
KAGAN21
ok well i guess the search continues. thanks for the help.
Old Mar 13, 2018 | 12:19 AM
mrollings53's Avatar
mrollings53
Buy a steel cover, then weld in a bung for a sensor.
Old Mar 13, 2018 | 04:56 PM
Diesel_Brad
Just drill and tap the housing or the cover
Old Mar 17, 2018 | 06:57 PM
KAGAN21's Avatar
KAGAN21
where on the diff cover do i drill at?
Old Mar 17, 2018 | 07:44 PM
mrollings53
Somewhere below the fluid level, away from the ring gear.
Old Mar 17, 2018 | 08:22 PM
KAGAN21's Avatar
KAGAN21
ok thank and another question would be im thinking about getting a oil temp gauge too but i don't know where to mount the sucker any ideas? 5.0L motor
Old Mar 18, 2018 | 03:16 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
For the gauge itself or the temp sensor? I would mount the gauge to the dash. The sensor might be trickier, maybe an alternator oil pan with a sensor port?
Old Mar 18, 2018 | 12:06 PM
GoinBoarding's Avatar
GoinBoarding
I'm curious, what are you using this truck for? Are you interested to know these temperatures just for fun (no judgement there, I enjoy data) or is this thing getting worked over hard?
Old Mar 18, 2018 | 05:55 PM
KAGAN21's Avatar
KAGAN21
well right now i have a coolant temp, volt gauge, and oil pressure. running 33x10.50 tires with 3.73 gears and im planning on upgrading the trailer plug to a 7 way and trailer brake with trans cooler for pulling cars around mainly. the gauges im looking to install now is trans temp, diff temp, oil temp and maybe a fuel pressure(not for sure on that one) just to see how the old girl is doing. truck right now is just for playin around the fields, trail riding, and as i said before haul cars around here and there.
Old Mar 19, 2018 | 04:05 PM
Diesel_Brad
With 33's and a small block towing I would be more concerned about the gearing than temps
Old Mar 19, 2018 | 05:29 PM
KAGAN21's Avatar
KAGAN21
well at the time i bought it she had 3.11 in it with 33x12.50 tires. but at the time i was going to 3.73 i was not planing on hauling some cars around, should have went with 4.11
Old Apr 8, 2018 | 05:13 PM
KAGAN21's Avatar
KAGAN21
and plus im not going to haul cars all the time just one random here and there mainly. im pretty sure the old girl can pull a 3000lbs car and trailer.
