Gears
Old Mar 11, 2018 | 11:21 PM
stangDiesel's Avatar
stangDiesel
Gears
I have a gasser with 3.73 gears and I want some more pep in the step. Besides the 4.30 oem gears, what brand and sizes are available out there?
thanks
Old Mar 11, 2018 | 11:22 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
SRW or DRW?
Old Mar 12, 2018 | 08:32 AM
stangDiesel
Originally Posted by Alaskan_Warbird
SRW or DRW?
the truck is a SRW, 4x4
Old Mar 12, 2018 | 09:56 AM
J Standard's Avatar
J Standard
What size tires are you running? Most guys run 35's and they simply suck the power out of a 6.2, some 4.56's will put it back where it needs to be, given the option I would run a 4.88 with 35's as that would allow the 6.2 to pull in 5th/6th.
Old Mar 12, 2018 | 11:25 AM
stangDiesel
I just went to 35's the other day. 4.56 and sounds good.
Old Mar 12, 2018 | 04:45 PM
stangDiesel
Who offers the higher gear ratios?
Old Mar 12, 2018 | 05:54 PM
cattaco's Avatar
cattaco
I wouldn't jump to 4.56 is all you are going to run is 35's. I believe a truck with 37's and 4.30 is still geared lower than a truck with 33's and 3.73.
Old Mar 12, 2018 | 10:03 PM
Snowman 8's Avatar
Snowman 8
I have a 6.2 with 4.30’s and installed 35’s a few months ago. The truck had the 275/70/18’s and it should have changed my effective ratio to about a 4.1 or so. That’s what I remember looking up prior to making the tire change. The seat of the pants feel isn’t much different in acceleration or performance either. My mileage hasn’t changed enough to notice either. I just found a tire size/gear calculator online and you can enter in your combinations and it will give you the effective ratio.
Old Mar 12, 2018 | 10:17 PM
stangDiesel
Ok. But if I made a move what is the best brand out there?
Old Mar 20, 2018 | 03:04 AM
stangDiesel
Does Nitro make gears for our trucks and if so are they pretty good?
Old Mar 20, 2018 | 06:35 AM
System's Avatar
System
Prolocutor
Many like Yukon. Randy's is a popular place to check what's available and order. Since you have a gasser, you have the Sterling 10.5 as opposed to the DANA M275. I tried looking up a 2017 on Randy's site and they only show M275 options that fit the 6.7. However, I searched by Ford 10.5 and see all the options for your Sterling diff. Don't forget, since your 4x4, you'll need to do the front too. https://www.ringpinion.com/DiffWizard.aspx
Old Mar 20, 2018 | 08:16 AM
BronzefireAL13SD's Avatar
BronzefireAL13SD
https://eastcoastgearsupply.com/
I ran 4.88 yukons in my 6.2L Sierra. It was a beast even with the 38/15.50 hankooks.
Old Mar 20, 2018 | 10:51 AM
Buliwyf's Avatar
Buliwyf
Don't fear the gear.
4.30 is a waste of $2000. If you're going to do it, go 4.56 (36") or 4.88 (38"). 4.30 is hardly an improvement with the gasser, maybe perfect with the diesel though. Yukon has the proper gears. Add a Yukon Grizzly locker up front at the same time, or the zip locker if you can't handle a Detroit style diff. It's only $500 more and takes the F250 Fx4 to Powerwagon levels of 4x4 competence.
Old Mar 20, 2018 | 02:58 PM
stangDiesel
lim running 35's now but I may opt for 37's. How does Yukon 4.88 sound with this set up? Or would 4.56 suffice? What rpm do those run at 70 mph?
thanks
Old Mar 20, 2018 | 03:14 PM
stangDiesel
a
thanks sir
