Modular V10 (6.8l)
6.0 oil cooler in my 1999 F350 dually
Old 03-10-2018, 08:02 PM
billybobofkf's Avatar
billybobofkf
billybobofkf is offline
I’ve been planning this upgrade for a while now. Installed a ford 6.0 transmission oil cooler in our F350 gas engine truck. This is a popular upgrade on F350s with a 7.3 diesel or a 6.8 gas engine. As you can see in one picture the new cooler is roughly twice the surface area of the old cooler and it is a bolt in modification. Hopefully this will solve our cooling issues when towing on hot days.
Also got to use my Sidewinder ratchet! It’s a lifesaver in tight quarters.
Old 03-15-2018, 02:54 AM
AllAboutDaZ's Avatar
AllAboutDaZ
AllAboutDaZ is offline
should make a big diff when towing on trans temps
Old 03-16-2018, 07:37 AM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
Before I did the conversion, my trans temps would get into the low 220's on hills and would stay in the low 200's on flats. After the upgrade, trans temps rarely see the 190's.
Old 03-24-2018, 11:04 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Agree, once done I've never gotten over 190F.
Old 06-16-2018, 10:01 PM
billybobofkf
We did our first tow with the new oil cooler combination. We never topped 170 degrees, with an outside air temperature of 75, and a climb from 4500' to 5200'. The trip home will be a better test with a climb from 0 altitude over a 5200' pass.
Old 06-17-2018, 09:14 PM
GOT-DRT's Avatar
GOT-DRT
GOT-DRT is offline
What brand trans cooler did you purchase? OEM or aftermarket
Old 06-17-2018, 11:02 PM
R&T Babich's Avatar
R&T Babich
R&T Babich is offline
I used the Dorman 918-216 aftermarket version in our Ex and it works great.
The 6.0 cooler uses 1/2" diameter tubing (OEM is 3/8") which reduces the cooler line pressure.
The lower line pressure allows use of a 3rd cooler and a filter, if desired, without exceeding the OEM line pressure and possibly opening the cooler line bypass valve.
Old 06-18-2018, 07:57 PM
billybobofkf
That is an OEM oil cooler.
Old 06-19-2018, 07:51 PM
billybobofkf
Update: Climbed from zero to 5200' altitude towing a 31' 5th wheel trailer today. Max transmission temperature hit 210 and held there. It took quite a while at 4000rpm, 45mph in 2nd gear to climb from 160 to 210. The hardest part of the climb was maybe a 10 mile climb. The outside air temperature at the top of the pass was about 55 degrees, so I'll need to pull over and let the trans temp cool down on a hot day. Normal temperature on flatland is now 160 degrees. 210 degrees is hotter then I had hoped for, but of course it is a big improvement over the stock transmission oil cooler that was not running through the radiator.
Old 06-20-2018, 12:12 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by billybobofkf
... 210 degrees is hotter then I had hoped for, but of course it is a big improvement over the stock transmission oil cooler that was not running through the radiator.
Adding a B&M 70274 Supercooler after the 6.0 cooler would drop those peak temps down another 20 deg or so.
It's ports are 1/2" NPT so I use an adapter fitting that takes it to 1/2" hose.
Old 06-27-2018, 01:13 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
recommends against stacked coolers. Being he helped Engineer the 4R100 I tend to follow his advice.
@billybobofkf do you have the newer radiator with the transmission fluid running through it?
I found my temps drop quicker after adding the OTW cooler and removing the extra tube and fin. I however am not towing heavy like you are though.
Old 06-27-2018, 08:58 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by Bently_Coop
recommends against stacked coolers. ....
Ford used stacked plate coolers as aux trans coolers, PS coolers and engine oil coolers.
Or was the recommendation against stacking coolers in front of another?
I added the B&M cooler above the other one.
Old 06-28-2018, 02:12 AM
Bently_Coop
Against stacking coolers, multiple coolers inline with each other.
My apologies on the wording.
Old 06-28-2018, 06:40 PM
billybobofkf
Yes, I bought a OTW radiator on your recommendation. I'm running the fluid from the transmission into the radiator, from the radiator to the trans oil cooler and back to the transmission.
Also, I realized that I forgot to take my front license plate off. It is halfway blocking the hole where airflow runs through. If I take the license plate off, I'll have better airflow through the trans oil cooler, maybe up to twice the airflow,
I'm now considering building a little fan setup to set in that hole to speed up cool down if I have to pull over climbing a mountain.
We have another trip planned in July that will take us over two mountain passes, so there will be plenty of time to rethink this issue.
Old 06-28-2018, 07:07 PM
billybobofkf
Mark Kovalsky doesn't recommend running multiple oil coolers in series due to the possibility of activating the low pressure bypass. I understand that you are running two coolers successfully, but I don't believe that I'm up for trying it.
Quick Reply: 6.0 oil cooler in my 1999 F350 dually
