6.0 oil cooler in my 1999 F350 dually
I’ve been planning this upgrade for a while now. Installed a ford 6.0 transmission oil cooler in our F350 gas engine truck. This is a popular upgrade on F350s with a 7.3 diesel or a 6.8 gas engine. As you can see in one picture the new cooler is roughly twice the surface area of the old cooler and it is a bolt in modification. Hopefully this will solve our cooling issues when towing on hot days.
Also got to use my Sidewinder ratchet! It’s a lifesaver in tight quarters.
I used the Dorman 918-216 aftermarket version in our Ex and it works great.
The 6.0 cooler uses 1/2" diameter tubing (OEM is 3/8") which reduces the cooler line pressure.
The lower line pressure allows use of a 3rd cooler and a filter, if desired, without exceeding the OEM line pressure and possibly opening the cooler line bypass valve.
Update: Climbed from zero to 5200' altitude towing a 31' 5th wheel trailer today. Max transmission temperature hit 210 and held there. It took quite a while at 4000rpm, 45mph in 2nd gear to climb from 160 to 210. The hardest part of the climb was maybe a 10 mile climb. The outside air temperature at the top of the pass was about 55 degrees, so I'll need to pull over and let the trans temp cool down on a hot day. Normal temperature on flatland is now 160 degrees. 210 degrees is hotter then I had hoped for, but of course it is a big improvement over the stock transmission oil cooler that was not running through the radiator.
It's ports are 1/2" NPT so I use an adapter fitting that takes it to 1/2" hose.
recommends against stacked coolers. Being he helped Engineer the 4R100 I tend to follow his advice.
@billybobofkf do you have the newer radiator with the transmission fluid running through it?
I found my temps drop quicker after adding the OTW cooler and removing the extra tube and fin. I however am not towing heavy like you are though.
Also, I realized that I forgot to take my front license plate off. It is halfway blocking the hole where airflow runs through. If I take the license plate off, I'll have better airflow through the trans oil cooler, maybe up to twice the airflow,
I'm now considering building a little fan setup to set in that hole to speed up cool down if I have to pull over climbing a mountain.
We have another trip planned in July that will take us over two mountain passes, so there will be plenty of time to rethink this issue.
Mark Kovalsky doesn't recommend running multiple oil coolers in series due to the possibility of activating the low pressure bypass. I understand that you are running two coolers successfully, but I don't believe that I'm up for trying it.
