I just bought a new hpop and I know all the torque specs, but when I go and try and torque down the 18mm it just spins and it doesn't even come close to 95lbs. I have the crank shaft held, but it's the bearing inside of the hpop that keeps spinning. Any suggestions
It's been a couple of years since I replaced my HPOP but I want to say that I had to put a small prybar on the gear to keep it from turning when I torqued the nut.
Somethings' wrong. I just installed mine a few weeks back with no issues. Cranked nut to65# before i had to lock the crank down. From there, torqued nut to 95#
