2000 7.3 hpop torque problems
Old Mar 10, 2018 | 03:10 PM
Brett Davis's Avatar
Brett Davis
I just bought a new hpop and I know all the torque specs, but when I go and try and torque down the 18mm it just spins and it doesn't even come close to 95lbs. I have the crank shaft held, but it's the bearing inside of the hpop that keeps spinning. Any suggestions
Old Mar 10, 2018 | 03:51 PM
Walleye Hunter's Avatar
Walleye Hunter
That shouldn't happen if you have the gear engaged properly with the one below it.
Old Mar 13, 2018 | 10:48 AM
brian42's Avatar
brian42
Veteran: Navy
It's been a couple of years since I replaced my HPOP but I want to say that I had to put a small prybar on the gear to keep it from turning when I torqued the nut.
Old Mar 13, 2018 | 12:02 PM
timmyboy76's Avatar
timmyboy76
Somethings' wrong. I just installed mine a few weeks back with no issues. Cranked nut to65# before i had to lock the crank down. From there, torqued nut to 95#
Eric Kropp
Nov 1, 2014 10:12 AM
murph1
2009 - 2014 F150
Nov 27, 2009 03:15 PM
JimG1098
May 2, 2007 05:25 PM
ford190082
Jun 27, 2004 09:25 AM
enduro
Nov 11, 2002 11:36 AM
