I have an old habit of checking a motor, gas or diesel, by jumping the starter to quickly get a feel for cylinder balance. You don’t need the vid if you’ve got a reasonable handle on cylinder dropout.
I agree the vid doesn't shake like what I was expecting based on the comment of the blow out tire shaking and the driveway startup. The rhythm seems OK, but it sounds like a tractor motor. Phone and screen diag is always tough.
be able to tell that just thru a video of it cranking or will I need to actually set it up for a compression test?
If it sounds like this during cranking, it only has 7 cylinders with compression . I had a torched exhaust valve and slightly melted piston .
https://youtu.be/GOSrVP2_XB4
