Tuning with O2 sensor
#32
Originally Posted by Aaron-71
I'm wondering how a true dual set-up would benefit from a single O2 AFR set-up. Readings from only 1 of 2 headers may get you close, but not perfect on both sides, or equal on both sides of the motor. Any comments?
True dual ex. on my slick, thought about getting a bung installed in both pipes - and swapping over to check - but it hasn't seemed necessary. Tuning went great. Even with an O2 wideband setup still have to inspect plugs, and use your best judgment. Regardless of the indicated AFR for example, if you're seeing lean surge on the highway, it's too lean. If plugs are fouled, it's running rich, etc. Sometimes people place too much emphasis on the numbers and obsessing on that stuff. Not having to worry so much about roasting a valve while experimenting with carburetor tuning was nice, that's the benefit in my mind. I could really gain a better understanding of how each carburetor circuit works while jetting down, swapping in different power valves, and seeing how even very slight changes in tuning makes big changes in the AFR.
PapaBearYuma
23
04-24-2017 10:51 AM
81ChopTop
03-06-2017 01:39 PM
F-250 restorer
09-28-2013 10:45 PM
gtex
10-09-2004 08:49 PM
