Brake Tolerances?
Old Sep 16, 2003 | 02:57 PM
rabidranger's Avatar
rabidranger
Brake Tolerances?
I have a nasty pulse in my brakes with the D60 swap I just did. I can feel it even when the pedal is lightly depressed going about 5 mph, I can feel the pedal moving up and down. So I think it is bad rotors. I put a mag base dial indicator on the axle and spun the tires. I only measured about .005" of wobble as it turned. Is that enought to cause brake pulsating? At speeds of 50+ mph it is horrible, and begins to cause death wobble if I brake even harder. Sometimes the pass side locks up under moderate braking too. Any ideas?
