2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2017 Coolant Leak 6.7
Old 03-14-2018, 02:20 PM
Kdawg89's Avatar
Kdawg89
Kdawg89 is offline
Well the dealer has officially said they can't find the coolant leak, they agree that it is loosing coolant somewhere but can't find it. They worked with engineers at Ford and did a bunch of tests but couldn't find anything. One thing I noticed that I didn't give much thought to before was in the valley of my motor it is rust colored up in front of the turbo, I wonder if I am getting coolant in the valley and because it is so close to the exhaust manifolds it is evaporating before it ever gets to the ground and I just smell it. Anyone have any thoughts where coolant could be leaking from in the primary loop and then end up in the valley? This seems common enough with many people having the same symptoms that hopefully someones dealer will eventually figure it out and be able to solve it for a lot of us.
Old 03-14-2018, 02:40 PM
System's Avatar
System
System is offline
Prolocutor
Received 1,204 Likes on 578 Posts
My dealer couldn't find it either today. Very frustrating...
Old 03-14-2018, 02:46 PM
Kdawg89's Avatar
Kdawg89
Kdawg89 is offline
If you get a chance grab a flashlight and try and see into the valley of your motor (it is kind of a pain in the butt and don't burn your face on the EGR piping ) and see if it is a rust colored, I am really curious. They gave me a loaner 2017 SD 6.7 with nearly the same build date as my truck so I am going to check that one out before I give it back, I also noticed it smelled like coolant when I parked it last night. I am starting to wonder just how many of these trucks this affects. My dad had a 2013 6.7 and it never lost an ounce of coolant over the few years he had it.
Old 03-14-2018, 02:48 PM
System's Avatar
System
System is offline
Prolocutor
I will check in a few hours when I pick it up. I too had a 2012 6.7 and never added coolant in 5 years of ownership.
C12H24's Avatar
C12H24
C12H24 is offline
If they don't dye mark it, you will be chasing this until the source aggravates enough to be come apparent to even a blind man. I understand the techs not wanting your truck to become their life's work...being paid flat rate on the job and all, but for a lot of problems, testing won' produce a result. The static and dynamic conditions of the cooling system are entirely different. If, during the testing, there is no method to duplicate the dynamic conditions in the cooling system, then it may not show up. I feel for ya' but it will be resolved once it becomes bad enough.
Old 03-15-2018, 07:35 PM
Kdawg89's Avatar
Kdawg89
Kdawg89 is offline
I found my leak! At least a leak hopefully it’s the only one! Here are some pics showing the location, hopefully when I point it out to Ford they will just order the hose and fix it! It is leaking from the passenger side of the plastic tee and running down the side of the air intake tube and dripping onto the alternator.
Old 03-15-2018, 07:45 PM
Kdawg89's Avatar
Kdawg89
Kdawg89 is offline
From the pics with the flash it looks really obvious but it isn’t that easy to see with the naked eye.
Old 03-15-2018, 07:48 PM
System's Avatar
System
System is offline
Prolocutor
WHOAAAAA! You're awesome! Just checked and mine is leaking in the same place. Heading to the dealer tomorrow to show them and get a new hose assembly ordered. Thanks so much for your vigilance....
Old 03-15-2018, 07:57 PM
Kdawg89's Avatar
Kdawg89
Kdawg89 is offline
Excellent, hopefully this is the end of the leaks for both of us and more. I can’t believe they had my truck for 3 days and didn’t notice a hose leaking right on top of everything. Granted it is quite a bit harder to see with your eyes than in those photos.
Old 03-15-2018, 07:58 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
I love it when they try to discount forum guys!!
Old 03-15-2018, 08:04 PM
System's Avatar
System
System is offline
Prolocutor
Just took pics of mine. Hard to see on camera but orange coolant on my fingertip. It just looks like the plastic is a little bit shinier where the coolant has been on it.
Old 03-15-2018, 08:06 PM
System's Avatar
System
System is offline
Prolocutor
My buddy just checked his and it's also leaking from the same spot. See the video.
File Type: mov
  #28
Old 03-15-2018, 08:07 PM
Kdawg89's Avatar
Kdawg89
Kdawg89 is offline
Ha, my trip to the sand dunes over the weekend was actually a big help. It would have been nearly impossible to see if it weren’t so dirty on that air intake.
  #29
Old 03-15-2018, 08:36 PM
nxtdiesel's Avatar
nxtdiesel
nxtdiesel is offline
I'll have to check mine tomorrow, I can occasionally smell antifreeze on mine also but haven't been able to find any leaks anywhere. Neither of the bottles on my truck were low but I went ahead and put a couple marks on them so I could check and see if it drops at all.
  #30
Old 03-15-2018, 09:24 PM
ysgi's Avatar
ysgi
ysgi is offline
Mine smells like coolant almost every day. I have never found a leak though. But the reservoir is low. I will need to check these hoses tomorrow. Thanks guys.
Quick Reply: 2017 Coolant Leak 6.7
