Sponsored by: Real Truck
Bkkst xrops off while tiwing
Old Mar 5, 2018 | 08:54 AM
relayman53's Avatar
relayman53
2006 F250 SUPER DUTY 6.0. STUDDED, LOTS OF UPGRADES. SCT PROGRAMNER
WHEN TOWING MY FIFTH WHEEL CAMPER, MY BOOST USUALLY RUNS ABOUT 20, AND VARIES WITH TERRAIN TO MAINTAIN TORQUE/ SPEED AS EXPECTED.
. LATELY WHILE TOWING MY 5TH WHEEL , WHEN THE TRUCK MAKES ITS FINAL SHIFT ( INTO OVERDRIVE I GUESS) BOOST DROPS TO NEARLY NOTHING...EXHAUST TEMPS START TO RISE , . BECAUSE IM HAVING TO GIVE IT MORE FUEL TO MAINTAIN SPEED, AND IT MAKES A LOW
" DRONING" NOISE. FINALLY I STAND ON IT TO DOWNSHIFT AND GET THE RPMS UP TO REDUCE THE EXHAUST TEMP. SOMETIMES IT WORKS NORMAL, SOMETIMES IT DOESENT. ANY IDEAS GUYS ?
Old Mar 5, 2018 | 02:26 PM
EXSwap's Avatar
EXSwap
Sounds like to me your turbo is in need of a serious cleaning. And maybe a rebuild and/or unison ring. Those are the mechanical issues. The solenoid that positions the vanes can be bad or malfunctioning. Are you changing oil at prescribed intervals (or other intervals based on using remote filtration)? Type of oil? Motorcraft filters?
You may do a bit better posting this in the 6.0 forum, but those are the basics. Other mods you've done to the engine will help diagnose problems as well. I'd also get through the 6.0L tech folder:
https://www.ford-trucks.com/forums/3...ch-folder.html
Old Mar 5, 2018 | 06:35 PM
DogRidesInBack's Avatar
DogRidesInBack
My bkkst never xrops off when tiwing.
You must have a bkkst leak, look for suet on your fir wall.
And please turn off your caps lock.
Old Mar 5, 2018 | 09:04 PM
Colorado350's Avatar
Colorado350
Does no one proofread anymore?
Old Mar 6, 2018 | 10:08 AM
Deuce40s's Avatar
Deuce40s
The only reason I opened this thread was to see if it bothered anyone else.
"They'll figure it out. Send it."
Old Mar 7, 2018 | 04:45 PM
ligito's Avatar
ligito
ShawnQ
Dec 31, 2018 10:31 PM
relayman53
Mar 5, 2018 11:13 AM
MAD
Aug 30, 2013 01:20 PM
frdf250
16
Jul 6, 2011 06:30 PM
Gental Ben 2
Jul 20, 2010 12:05 AM
