Sponsored by: Auxito
Imrc problems
Old Feb 28, 2018 | 07:20 AM
Andy Deleebeeck's Avatar
Andy Deleebeeck
Imrc problems
We have code 1537 and 1538 coming up on scanner we have had the intake off and have cleaned the intake and replaced both intake modules at the back of the intake and replaced the control module at the side of the plenum and also checked all the vacum lines and still have these codes still showing up on scanner .any other things to check we have tried everything .we need to get the truck fixed so we can do an emmions test done
Old Feb 28, 2018 | 08:58 AM
pdqford's Avatar
pdqford
What engine?
What year?
Old Feb 28, 2018 | 02:33 PM
Bluegrass 7's Avatar
Bluegrass 7
Those codes are for a V6. Both banks stuck open. I won't hurt the engine but the small loss in lower end torque.
Clear the codes if you have not done so or your looking at old history after the work was done..
Make sure both are free to move.
Good luck.
Old Sep 30, 2023 | 06:16 AM
frederick sikes's Avatar
frederick sikes
4th Gear
Question same problem 1537 1538
hello new here . I have a 97 F150 I changed both IMRC actuators and there doesn't seem to be any vacuum leaks but I can't get these codes to go away . Any suggestions on what it might be before I purchase a new PCM ?
Old Sep 30, 2023 | 08:37 AM
Johnny Paycheck's Avatar
Johnny Paycheck
What makes you think the computer is at fault?
You know what mileage is on the engine. Pull plugs, check for compression and blow by.
Eventually, these 4.2s burns oil and the butterflies are forced open. About to swap an engine that’s dealing with that right now.
Edit: If that mileage number in your profile is correct, then I’m not shocked.
Old Sep 30, 2023 | 12:02 PM
BareBonesXL's Avatar
BareBonesXL
1997 uses vacuum to open the butterfly valves and an electrical switch to open a valve to apply the vacuum. I would focus on understanding what feedback the PCM gets to know if the valves are open or closed. The PCM actuates the switch but must be getting a signal back from somewhere to know if its command has been met.
Old Sep 30, 2023 | 01:58 PM
BareBonesXL
This guy's video is informative. Something different, doesn't look like you checked there. There's probably a way to check its function through the pinout. It's the electrical switch that opens the vacuum control valve.
Old Oct 1, 2023 | 03:26 AM
frederick sikes
4th Gear
Thats the first thing I replaced .
Old Oct 1, 2023 | 03:31 AM
frederick sikes
4th Gear
they're both stuck open , They both moved freely when I replaced the actuators ,I can't find any vacuum leaks and no change in running when I spray carb cleaner around the plenum and vacuum connection .
Old Oct 1, 2023 | 03:37 AM
frederick sikes
4th Gear
same here it's frustrating, I'll keep checking the posts mayby someone has remedied this before .
Old Oct 1, 2023 | 05:11 AM
manicmechanic007's Avatar
manicmechanic007
The vacuum canister (above the RF inner fender) needs to be checked and its related hoses and one-way valves checked
The one behind the battery does not usually crack but check that one too
Use a a hand held vacuum pump and see if they both hold vacuum
Old Oct 1, 2023 | 10:04 AM
BareBonesXL
Spraying carb cleaner won't find the kind of vacuum problem you're looking for. Besides that the PCM reacts too quickly to hear any change in engine RPM. It doesn't work on these engines.
That electrical switch is in the middle of the vacuum path. If I understand the system correctly the valves are normally open. When there is no vacuum a spring opens the valves. So, one simple way to break your problem in half is to check for vacuum at that switch I linked to. If there's no vacuum at the switch then the problem is before the switch, in the vacuum supply to the switch. If there is vacuum, and the switch is opening when the engine is idling (check for vacuum on the downstream side), then the problem is after the switch, in the hoses or the actuators. If the switch isn't opening then there's a problem with the switch or the wiring.
Short - find out what is happening at the vacuum control switch.
Old Oct 10, 2023 | 02:20 PM
fredericksikes's Avatar
fredericksikes
3rd Gear
finally figured it out .
well after pulling my hair out and replacing every darn thing that can be replaced to no avail, this video popped up on youtube that fixed everything. What finally work was simply resetting the ECM by removing and touching the + & - battery cables together for 4 min's . I'll be darned it worked , after going through a drive cycle the IM readiness is all good and no codes. So I hope this can help someone else who might be struggling with this issue in the future. Thanks everyone for your ideas .
Old Oct 10, 2023 | 03:23 PM
BareBonesXL
How about a link to the video?
Seems odd. Hope it stays fixed for you.
Old Oct 10, 2023 | 09:36 PM
fredericksikes
3rd Gear
link to reset computer
