2003 expedition won't start
Old Feb 27, 2018 | 01:55 PM
1999f350farmtruck7.3's Avatar
Thanks for reading . My 2003 expedition has a 1year old battery, alternator is 6 months old. I checked voltage of battery is 12.4 when truck is on the voltage jumps to over 13.4. But when I go to start truck i t doesn' start unless my jumper is connected . What could this be ?? Where' does the ground go too?? Can' see end, also could it be the starter failing I've never replaced it and it has 206000 miles. My f350 failed after 180,000 miles. Is there a regulator that' failing any help would be great.
matt
Old Feb 27, 2018 | 02:20 PM
Hamfisted's Avatar
Hamfisted
Are the battery terminals clean and in good shape ? Is it a Group 65 battery ? Not a AutoZone Duralast POS is it ?
-Mike
Old Feb 27, 2018 | 09:29 PM
I replaced the terminals, it's a interstate 65 battery. Can anybody that is experienced with repair have any ideas what's going on.
Matt
Old Feb 27, 2018 | 10:46 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Cranks/Turns over = spins but not start
Start = engine fires off
We need to know which terminology you are using to describe your problem. Is it clicking but not turning over, or is it turning over but not starting?
Your negative battery cable goes down to the engine block and the frame.
Old Feb 28, 2018 | 08:27 AM
alloro's Avatar
alloro
The alternator output is low. You need at least 13.8v to charge the battery.
Old Feb 28, 2018 | 08:55 PM
R&T Babich's Avatar
R&T Babich
I thought the normal maximum charging voltage should not exceed 13.8v for long periods and 14.4v for periods up to 8 hrs.
Also, any voltage higher that 12.4v will charge the battery, but 13.8v is optimum.
Our 2003 Exped works exactly like this - 14.4v right after starting and drops to 13.7-13.9v after 20 min or so.
Our 2002 Excur goes to 13.6v after starting and drops to 13.2v.
I've checked this using several voltmeters because the lower voltages on the Excur seemed odd.
Both have been working fine with no battery issues for several years.
http://www.operatingtech.com/lib/pdf...20Charging.pdf
Old Mar 1, 2018 | 08:04 AM
alloro's Avatar
alloro
Because the battery is charged so the voltage backs off. If however the voltage never got above 13.4v to charge the battery it will eventually get weaker and weaker. It'll happen even faster with accessories and headlamps turned on.
Old Mar 1, 2018 | 12:25 PM
pdqford's Avatar
pdqford
The colder the battery is the more voltage it takes to actually push current into it.
Here in Central NY State with temps in the single digits and lower I like to see 14.7 to 14.9 volts after start up, eventually dropping to 14.2 to 14.4 volts.
Not sure what temps the OP is dealing with.
sammatt1
Mar 24, 2014 01:00 AM
murphym84
16
Dec 26, 2011 05:05 PM
surf_ox
May 8, 2010 07:06 PM
prohopwer
Nov 21, 2006 08:19 PM
JoyfulSoul
Electrical Systems/Wiring
Mar 6, 2006 05:34 PM
