Distributors...
Old Feb 26, 2018 | 08:00 PM
Mike1376's Avatar
Mike1376
Distributors...
hey y’all, I’m about to replace the dizzy on the 302 in my ‘84 F150. It is an early build so has vacuum advance. I have plans to upgrade to 4 bbl, intake, cam and exhaust... MAYBE heads.
Anyhoo, what’s a good aftermarket distributor that isn’t too dang expensive?
In case some of y’all are wondering why I’m wanting to replace it: it has an erratic idle that stumbles around especially while in gear and brake pedal applied. I put a timing light on it, the light jumps around a bit.
appreciate any.... ALL info from you fellas
Old Feb 26, 2018 | 10:10 PM
ctubutis's Avatar
ctubutis
My first thought is a stretched-out timing chain.
Old Feb 27, 2018 | 06:51 AM
FuzzFace2's Avatar
FuzzFace2
X2
set the motor on TDC remove distributor cap.
now turn the crank by hand till the rotor starts to move. Then turn crank in other direction and note how much it turns before the rotor does should not be more than about 2 to 4 degrees.
Dave - - - -
Old Feb 27, 2018 | 06:57 AM
Mike1376's Avatar
Mike1376
X2
Dave - - - -
Good thought gents. I’ll do that today. Would a timing chain stretch after 103k miles?
Old Feb 27, 2018 | 08:23 AM
Mike1376's Avatar
Mike1376
Also, is there a good double roller set that would be good to replace it with? May as well right?
cadunkle's Avatar
cadunkle
Duraspark II is a good system. First you should check whether you ever have any problems with your distributor. Check for side to side movement in the shaft, this indicated worn out bushings needing replacement. Also check that the mechanical advance operates smoothly and full returns to the same position each time. Mechanical advance is easy to clean and lubricate to ensure proper operation.
Old Feb 27, 2018 | 09:02 AM
Mike1376's Avatar
Mike1376
Oh yeah I’ll definitely check it all first before spending $$. Duraspark II.... I’ll check that one out, it’ll be a direct replacement? In other words I won’t need to make any mods to stab it in?
Thank uou
Old Feb 27, 2018 | 09:10 AM
Rembrant's Avatar
Rembrant
I just disassembled my '84 302 with only 36,000 miles on it, and the timing chain was so sloppy it looked like it would fall off...lol. However, I had checked the timing and it was nice and steady, so I don't know what to tell ya. My distributor shaft seems nice and tight, and everything inside the distributor appeared to be properly intact.
Old Feb 27, 2018 | 10:55 AM
Filthy Beast's Avatar
Filthy Beast
An 84 engine? You should have the DSII in there now, no?
103K miles...yes, I would say the timing chain would have some play in it......
Old Feb 27, 2018 | 11:05 AM
cadunkle's Avatar
cadunkle
You have Duraspark II, evaluate condition of the distributor and rebuild if necessary. Recurve it to optimize power and economy, from the factory mechanical advance tends to come in pretty late.
Old Feb 27, 2018 | 11:50 AM
Mike1376's Avatar
Mike1376
dang! Ok so yeah mine is probably way loose! Haha.
I know that every time I’ve had the timing light jump around, the distributor needed rebuild/replacement..
Old Feb 27, 2018 | 11:55 AM
Mike1376's Avatar
Mike1376
I haven’t spent a lot of my time on ford engines.m so wasn’t sure what mileage intervals those get changed at. Also, my initial thought was, I just got this truck a couple weeks ago so I would imagine if they get loose at 36k miles, maybe it’d been replaced already.... maybe twice. Who knows.
this is an early build ‘84. It was the transition year from non feedback to feedback carb, electronic advance and the EEC-IV computer. I’m not sure about the Duraspark II but Cadunkle says it is. I can try and find a part number and check it out
ive got vac advance, non feedback carb
Old Feb 27, 2018 | 11:56 AM
Mike1376's Avatar
Mike1376
ill check it all out. I’d prefer an upgrade but if the Duraspark II is good then it’s worth the rebuild. Thanks sir
Old Feb 27, 2018 | 11:02 PM
Mike1376's Avatar
Mike1376
So, I’m still curious. What is a good aftermarket dizzy that won’t break the bank?
Old Feb 28, 2018 | 03:56 AM
Rembrant's Avatar
Rembrant
Not sure what you consider too expensive, but if I was going to spend the extra coin on an aftermarket 302 distributor, I'd look at a custom curved unit from Performance Distributors:
Ford Duraspark - Performance Distributors Performance Distributors
You'll have to select your engine in the drop-down box.
Otherwise, there are a lot of options. The Pertronix ones have come up in a lot of my searches...not for trucks necessarily, but on old cars.
I'm just going through the process of upgrading my '84 302, same as you are. GT40 heads, 4bbl Edelbrock intake, Holley carb, Comp Cams full kit, headers, etc. I mulled over the distributor for quite a while, and in the end I decided to just order a stock reman unit from RockAuto, and the Crane Cams advance re-curve kit from Jegs.
This thing was supposed to be kind of a budget build, so I've been struggling to keep the costs down...lol. My truck is going to see very little use, and when it does get used, it will just be cruising, never hauling anything more than it's own weight. I think a performance distributor would be overkill for what I'm doing, so I just stayed stock but will re-curve the advance for performance.
If I was going to step up from here, I was going to go with one of those custom curved Performance Distributors.
