Carriage Works Billet Grill Install
I just purchased a Carriage Works Brushed Billet Grill. I can't figure out what part of the grill housing gets cut? Or what I should use to cut the plactic housing. Has anyone istalled one? If so, what did you use to cut the plastic housing? And what part did you cut?
I didn't cut anything when I installed my aluminum grille (I can't recall the maker). All three of the "egg-crate" inserts in the Excursion's grille can be removed WITHOUT cutting. If you study their retaining clips closely, you will see where 1 or 2 small screwdrivers will disassemble the whole shooting match.
