Fuel Pressure Regulator Question
Old Feb 25, 2018 | 11:17 PM
Northernroots122's Avatar
Northernroots122
Looks to be missing the plastic cap from the fuel restriction sensor??
Had a question, I am in the process of cleaning the screen on the FPR and took it apart to replace some o-rings (seal kit 2C3Z-9157-AA) and took off the snap ring and brass cap and pulled out the metal filter too clean it. On the write up I was looking at said to remove the plastic cap from the fuel restriction sensor. However, it appears there is not one on there to remove. I am curious if that is a concern or I need to try and find a little cap somewhere? Also if getting the brass cap back on all the way that the snap ring will actually fit in its groove is suppose to be that hard? Seems to want to set in on one side or the other but not ho all the way down. Tried putting on before realizing the “cap” was not actually there.
Old Feb 26, 2018 | 12:53 PM
dclack's Avatar
dclack
Not sure on the plastic cap, but to get the brass cap back on you need to use a C-clamp to compress it. I tried it they way you are describing and only managed to cut my new o-ring.
Old Feb 26, 2018 | 02:23 PM
Northernroots122
Thanks, that would work. Yeah I am not sure on the cap myself. It has a black plastic piece in there, kinda of a plastic threaded screw that pulls out easy enough, but seems to be missing the “cap” assuming that is something other than the threaded piece itself.
Old Feb 26, 2018 | 03:24 PM
dclack's Avatar
dclack
Well, if no one else chimes in, I've got a couple regulators on the shelf at home that I can take apart and check.
Old Feb 26, 2018 | 08:16 PM
dclack's Avatar
dclack
I busted one of mine open and here's what I found...
Old Feb 26, 2018 | 08:21 PM
dclack's Avatar
dclack
Looks like yours is there but maybe missing a piece. Mine just slid out; it looks like a screw but it's not.
Old Feb 26, 2018 | 08:28 PM
madpogue's Avatar
madpogue
It's all one piece, right? Looks like the top broke off the OP's part.
Old Feb 26, 2018 | 08:36 PM
dclack's Avatar
dclack
Yes, it's one piece. OP does appear to be missing the top part. Not sure if it will make any difference or not.
Old Feb 27, 2018 | 08:10 PM
Northernroots122
Interesting, when I took mine apart it had that black spiral piece, but it seems as though the top flat part that looks like the cap is just missing from it. Interesting, I wonder how that would have happened. I didn’t see it when taken apart, so 99% sure it did t fall out when I opened it. Guess i will put it all back together and see how it works out. Thanks a ton for taking yours apart and taking a look at it, much appreciated.
Old Mar 3, 2018 | 04:07 PM
Northernroots122
So it seems i have another problem, which I can only guess is related to the FPR. I put it back in and have been driving the truck the last two days perfectly fine. I fired it up this afternoon just as normal, little smoky while warming and potent exhaust, makes the eyes burn some, but same as always. It was sitting in the driveway for a few minutes warming up while I was gathering stuff etc. and then suddenly died. Tried to fire it up again and nothing. after a few more attempts it would occasionally try and start to fire, but then die. If holding the throttle down, a couple times it fired and revved up, but then died. If not holding the pedal down it would just crank, but not fire, maybe give a cough like it wanted to fire but nothing.
Now just sitting in the driveway blocking the garage and cant get to start:/. Anyone have any thoughts on what it could be or what to check?
Old Mar 3, 2018 | 05:22 PM
Talyn's Avatar
Talyn
Always possible the FPR plunger is sticking, or you didn't get the spring on the nipple on the back side of the FPR nut and it popped loose and its building no fuel pressure because it finally popped loose.
Old Mar 3, 2018 | 05:53 PM
Northernroots122
Can take a took and see. Just seems odd that was running great for two days then just quite, but it did come off/loose...
Old Mar 3, 2018 | 06:55 PM
Talyn's Avatar
Talyn
Mine did that when somebody poured sand in my gas tank.
Every now and then a piece of silica got passed the screen and would freeze up my FPR.
I didn't know any of this at the time and figured my fuel pump went bad.
Took everything apart and replaced the pump, went to put the bowl back on and it was full of silica. was like. "oh that explains everything"
Old Mar 3, 2018 | 11:18 PM
dclack's Avatar
dclack
Well I don't know about the stock system, but with efuel my truck will run and drive (with serious lack of power) WITHOUT any fuel pressure and no power to the fuel pump. So I have a hard time believing that a bad spring in the regulator is causing it to not start.
Old Mar 4, 2018 | 12:57 PM
Northernroots122
I haven’t had a chance to pull the FPR back off or lock at anything else yes, windy, snowing and just too cold today, but my wife did go out this am and try to start it like yesterday it fired up but after idling for a bit, 5 minutes +\-, it died. Seems when cold will run but ones warms up will die and not start again. When it does die and you go to start it, saw people asking in other posts of other issues, the tach does not move and no smoke from exhaust at all. Not sure if that is anything important to note or not but...
