wiring diagram
Old Sep 16, 2003 | 07:00 AM
dunerider's Avatar
dunerider
wiring diagram
Could anyone tell me where i could down load a wiring diagram that shows the trailor brake pigtail plug in under the dash for a ford 1999 des. i have no 12v source and would like to trace it back to its starting piont. Help!!! Anyone Thanks
Old Sep 16, 2003 | 10:52 AM
GAV10's Avatar
GAV10
wiring diagram
Try this: http://www.rverscorner.com/wiring/7pole.html
ON EDIT: Realized you are asking about power under the dash....Sorry. When you say "99 des." Are you referring to a 1999 F-250 SuperDuty Diesel ? If so you must install one relay and one fuse in your main distribution block under the hood to get 12 VDC power. If you need more info. let me know and I can look it up when I get home.
Mark
Old Sep 16, 2003 | 11:46 AM
dunerider's Avatar
dunerider
wiring diagram
yes a ford 250 diesel s/d. so all i have to do is go to any auto store and get a relay and fuse or must i get them at the ford dealer. Thanks for the help if i run in to any more problem you bet i will be calling on you Thanks again Dunerider
