oil pressure
Old Feb 25, 2018 | 05:56 PM
crsrob2's Avatar
crsrob2
oil pressure
2011 f150 5.0L, 134k. 2 weeks ago oil pressure gauge dropped to 0 and back to normal. also, started making a loud squelch sound. oil and filter changed every 5k added some lucas and sea foam. I've changed the oil pressure sensor switch, replace upper belt and main drive belt. Still have same issues, truck runs fine with no negative performance issues. idles fine at 500-600 rpm, still has power to haul, steep grades etc. any ideas out there that could be the problem? TIA.
Old Feb 26, 2018 | 09:44 AM
alloro's Avatar
alloro
It's common for the plastic timing chain guides to break, fall to the bottom of the oil pan and clog the intake of the oil pickup.
Old Feb 26, 2018 | 07:51 PM
fastback89's Avatar
fastback89
It does sound like pickup is getting clogged. I'm not sure how easily pan can be removed but it might be worth a look?
heatseaker1
2004 - 2008 F150
Jul 7, 2014 07:52 AM
RangerJ1
1983 - 2012 Ranger & B-Series
Mar 21, 2009 12:05 PM
dlingner
Oct 13, 2008 08:08 PM
OldFords
17
Jun 4, 2007 03:03 AM
Lee250
28
Nov 23, 2006 12:16 PM
