If your not going to take it off to clean why would you wash all the crap down into the engine? Your picture shows a pretty clean metered orifice hole in the throttle plate and you say it runs fine, so I wouldn't even bother. If the engine is warm and you use a heat gun or hair dryer to warm plastic parts before removing them they don't normally break.
Why worry about the area behind the plate as long as it not showing a plate stop ridge of varnish?
The throttle plate 'stop' is set to prevent the plate from going fully closed because amount of air going by The plate is part of the Idle calibration and Dynamics.
If the plate were allowed to fully close on a hot engine, then it cools, you could not operate the throttle because the plate would have been stuck with the throttle body shrinking around it after cooling down.
On a fault free system, removing the IAC electrical plug drops the idle to BASE idle, not a stall point.
The difference should be 250 rpm +/- a small amount.
The system has to have an air supply tolerance to work with.
It's been that way with carburation a 100 years and from 1985 on Ford fuel injection systems. They both need an idle stop to keep the plate from fully closing.
Good luck.
Good luck.
This is great info. Because of educational responses like this, I keep returning to this forum. Keep up the great work, guys!!!!
I wish other vehicle forums could follow this example and not allow smart-alecs to ridicule someone needing help.
IF.....one was wanting to clean the back side of that throttle plate. I suggest removing the whole throttle body housing ( not just the throttle body). This way one reveals to the 2 interior EGR ports farther down stream the down turn of housing, which can get carboned up too. , Lime1GT makes a good point, so with whole housing off , your then not washing all that gunk down into the engine. Also the IAC comes off with it allowing easier access to it for cleaning and or replacement.
I've had good success cleaning my 4.2L V6 engine's TB by spraying TB cleaner onto an old athletic (clean) cotton sock and then sticking my hand into the sock like a hand puppet so that I can stick my fingers through the butterfly plate while holding it open with my other hand. I wear nitrile gloves while doing this. It doesn't take long and it's easy to do.
