1978 - 1996 Big Bronco
Ching Ching Sound????
Old Sep 16, 2003 | 03:35 AM
BigBlackBronco's Avatar
BigBlackBronco
Im worried about my truck, I have like a Ching Ching sound every time I hit a bump, have no clue what it is, but its driving me insane. I replaced my Autolocking Hubs with Warn Premium Lockers and Repacked the wheel bearing 2 days ago thinking that would solve the problem, but it didnt! Anyone got any suggestions?
Front End is basically new, I have a 6 inch Superlift, with the Prerunner Steering Kit.
Ive tried everything to get rid of this sound, including taking a rubber mallot and banging on stuff to see if I could track the sound.
Old Sep 16, 2003 | 08:13 AM
90EBBronco's Avatar
90EBBronco
Do you have a cash register in the back of the truck? That might cause a ching ching sound. Now on a more serious note annoying sounds come with older vehicles and are sometimes hard to diagnose. Try having someone else drive the truck while you climb all over the place trying to find out where the noise is coming from. ching-ching usually means metal on metal so that might help you diagnose it. Lift kits are always suspect as hardware and parts settle in after some time. Get under that thing and retorque anything that you can. It is basically a crap shoot, but Good Luck!
KJ
Old Sep 16, 2003 | 08:22 AM
bigric's Avatar
bigric
I found my ching-ching noise. One of the bolts that holds the passenger front plastic inner fender had backed out slightly, and the washer was making my ching sound. Start checking everything to make sure it's not loose.
Old Sep 16, 2003 | 09:24 AM
JBronco's Avatar
JBronco
Mine makes the same sound, but it's just from the mechanic's cash register.
Seriously, it's probably the front brake pads. They have clips in there that keep them from rattling, and if the clip is not tight or has fallen out it will make that sound over every bump. Check it out.
Old Sep 16, 2003 | 09:47 AM
Gacknar's Avatar
Gacknar
This may sound strange, (and when it happened to me I could not belive it ether)but the rivets that hold your crossmemders to your frame may be loos. My bronco has over 480,000 miles on it and mine were so loose that I had to have the front crossmemder on the driver side welded to the frame becouse one of the rivits was so loos it was allowing the frame to move arond slightley. It made this horible high piched ching sound on every bump. Once it was welded the sound went away.
I found it by laying in my back under the Bronco wile my wife turned the stering whele from left to right and could see the frame moving around the rivit.
But first I would try tightening all the bolts to the lift kit and putting some sort of lubrication on all the bushings.
Mine was probably just a case af exteme milage
Old Sep 17, 2003 | 02:24 AM
BigBlackBronco
Thanks eveyone for the replys, I will try everyone of your suggestions and let you know what I finally find.
Old Sep 17, 2003 | 02:27 AM
andym's Avatar
andym
I'm sorry, you have how many miles on your Bronco?
Old Sep 17, 2003 | 08:13 AM
Gacknar's Avatar
Gacknar
480,000
that's
four hundred and eighty thousand miles
and no its not the original engine or trans
Old Sep 17, 2003 | 09:46 AM
JBronco's Avatar
JBronco
I'm betting on the brake pads!
Old Sep 28, 2003 | 12:39 AM
94Bronco58's Avatar
94Bronco58
Probably your gas tank reminding you you need to buy more gas!!
OldMathGuy
34
Aug 23, 2018 07:50 PM
cruz2322
Feb 26, 2017 02:38 PM
Notmeofficer
Large Truck
Nov 29, 2016 01:10 PM
Schmitty133
Jan 26, 2010 11:31 PM
Papadawg
Nov 13, 2007 08:50 AM
