Towing capacity question
Old Feb 23, 2018 | 06:17 PM
Lkn's Avatar
Lkn
I have a ‘17 F150 6.5’ bed with 11400 towing capacity. Is it ok to tow a fifth wheel that weighs 10964#? If not what is tow weight I should stick with?
thanks.
Old Feb 23, 2018 | 06:27 PM
JKBrad's Avatar
JKBrad
Much to learn here. I think you’re asking a lot from your F150. Especially if you don’t have the HDPP. Look at page 21.
https://www.fleet.ford.com/resources...e_r2_Nov27.pdf
Old Feb 23, 2018 | 06:33 PM
Lkn's Avatar
Lkn
What is hdpp?
Have max tow pkg.
Old Feb 23, 2018 | 06:40 PM
JKBrad's Avatar
JKBrad
Heavy duty payload package. Look at the chart. Looks like you are maxed out at 10,300 lbs.
Old Feb 24, 2018 | 07:51 PM
dnewton3's Avatar
dnewton3
Will it work? Sure it will (as much as a short bed can with with a 5vr).
Question is ...
Are you going to be realistic with your expectations for acceleration, braking, turning, limited load capacity (at or over the GCWR I suspect), wind buffeting, etc?
Today's trucks are quite capable, but they are not miracles. Operating at or near the max will always leave some folks wanting "more" (acceleration, control, stopping power, etc).
Old Feb 25, 2018 | 10:27 AM
Skylaneman's Avatar
Skylaneman
thanks.
Here's a good explanation I found elsewhere. This is about a bumper pull trailer but the basics remain. The gist of it is no you aren't legal to tow that 5th wheel.
Ford says my truck has a "towing capacity" of 11,800#. Ever wonder how they got that number?
My truck has a payload rating of 1895#. A truck HAS to have a driver, so subtract 150# from that, giving 1745#.
Since a trailer should have 13% to 15% of its weight as tongue weight, Ford went conservative and used the 15% figure. Dividing 1745# by 15% gives a towing capacity of 11,600#.
Ford wants that "towing capacity" to look as high as possible, so they used a base model XL with no options which weighs less than my truck. When they did the "towing capacity" math with the lighter base model XL and one 150# driver, they came up with a "towing capacity" of 11,800#.
Now, if you add weight to the truck, you reduce its payload capacity, pound for pound. All your options add weight. All your camping gear adds weight. All your passengers add weight. Every pound of weight you add, from any source, subtracts a pound of payload capacity. Every pound of lost payload capacity (using the 15% number) reduces your "towing capacity" by 7#.
bigredtruckmi
All Things Towing
24
Jun 18, 2018 07:54 PM
Word5430
2009 - 2014 F150
Apr 21, 2017 07:58 AM
Buck268
2009 - 2014 F150
15
Sep 8, 2016 10:02 PM
LilredWagon
2009 - 2014 F150
17
Jan 15, 2014 03:13 PM
Brandon150
EcoBoost (all engine sizes)
Jul 25, 2011 09:51 PM
