Right bank dead.
Ok, I found it, fixed it and it runs like designed. I had been researching and read about disconnecting one set, starting up to see if it would come up on 6 instead of 4. I did that and that worked to isolate to 5 or 7. So I started pinning it out again and moving the connector would show a short to ground. pulled everything apart and one of the wires to #7 had been pinched under the valve cover hold down bolt. I am assuming it wouldn't read to ground in the pin out test but once the idm put power to the circuit it was enough to cause a fault.
Awesome.
I just repaired a similar problem with my 95. The left bank was not working, terrible idle and no power. Tested the wiring to injectors from the UVCH and IDM connector, all measured correctly. I was just about to order an IDM but thought I would take one more measurement. By accident I found continuity from the injector to glow plug in the UVCH. Photo below shows the problem. I had no glow plug continuity but 16 ohms injector pins to glow pin. Replaced valve cover gaskets just in case.
Thanks for all the assistance,
Larry
Burnt connector, inside the rocker cover
Larry
greagin
01-05-2008 09:35 PM
Gregg C.
12-13-2005 04:15 AM
MDB
01-04-2005 06:06 PM
