initial timing
Old Sep 15, 2003 | 01:51 PM
351 power's Avatar
351 power
initial timing
I have been working on a project that is about finished except for the timing. The 88 351w engine idles as under a load at the recommended 10 BTDC and idles much more freely at 18 BTDC. By removing the#1 plug I determined that I am at the right gear for the distributor. This is a points type distributor however, and I am not sure if this is a problem in relation to the cam. Can I run this or greater advance safely? Would it be possible to run without the vacuum advance so as to avoid overheating? Thank you.
Old Sep 15, 2003 | 03:26 PM
DW2455's Avatar
DW2455
initial timing
may first gues just on what you've said is maybe you ballancer ring has slipped, you could try removeing the #1 plug get the piston to the top on TDC then mark your balancer at the timming tab pointer, and use this as a refrence point for setting your timming, if you set your base timming 1/2 to 3/4 inch befroe this mark it should put you in the ball park. hope this helps. DW
Old Sep 16, 2003 | 06:22 AM
351 power's Avatar
351 power
initial timing
Currently the pointer does point to 0 on the balancer when the piston is at TDC. I will check it again because I may have missed some damage. Thanks.
