Does any one have any expearence on porting 97 heads?
Also is the cam shaft stright up on this year?
And last has any one in stalled roller rockers on a EFI engine or more directly what will fit under the stock valve covers?
Thanks Leadmic
You say the cam on an efi 460 goes "straight up" as would a 1968-71 cam would. WHAT IS the spec(lift/dur/050/overlap...)on the efi 460 cam. I'd like comparative specs to the 68-87(?)base cam. I have yet to see any appreciable torque out of my 91 460 motor. I still wonder what the compression ratio is but figure it to be 8.5 or so from measuring and cc'ing a similar engine's head at 97cc and miking the piston recess and dish,adding .042" for the gasket. E7/E8TE heads- with 1.98 int/1.66exh.. compared to 2.08 int 68-87 heads. I am ready to blame the cam for watery torque curves. I have a 260/270deg-.487"lift stick(cheap one from PAW) ready to go in that showed outrageous torque, set straight up on an early 460 I had with approx 10.8c.r.. I long ago got past the question of fuel mix, as I scanned the mix up and down during a long pull, finding optimum in that parameter. I did this both with my speed-density and now with my MAF conversion. As I said before I am dealing with multiple ailments at once here. BT
The EFI engines (or at least the 88-92) use a cam that dates back to 1968. In other words, the part number starts with C8. I haven't looked up which 68 engines used that cam though...
So I guess it is a "straight-up 68-up style cam. All the more reason to go to the PAW base grind. I cannot seem to get even the torque of a mid-70's smog motor and with a tad more compression yet (8.5 as opposed to 8.0)..
I have tried cams in my 4wd van with both the 460 and the 429, of :stock 68-up, M6250-A460, PAW's 260/270(liked it best 1500-4800), the 270/280 PAW, a crane HIT-292(never saw power due to mismatched lower range intake/carb((1850-list Holley)--I used the 292Crane to bleed off some of the 11.8:1 compression for pump gas-some help-power like the 270/280 grind. As I see it, most of us wish for more TORQUE in our 460's. Sometimes I do not mind treating the motor like a 289 and buzzing it. That is why God invented 429's with short stroke rev-ability. I could never tell the difference of outright HP-high end power, from a 460 over a 429. 460 has a slight edge at low revs and 429 better upstairs---my observations from my work done. I would really like to know the tricks to wake up LOW rpms in this motor. That is why our 13000 lb ambulance I drive walks away from my 6500 lb truck with the 460--torque in the realistic rpm range over a wide enough span... any hope out there naturally adpirated???
